Please Help ! I'm Confused
Discussion in 'The Garage' started by Frank, Jul 6, 2004.
  1. Frank
    Frank Registered Member
    Oct 2, 2001
    16
    Please Help ! I\'m Confused
    I have a 1987 chevy blazer 4x4, 305 CID motor equipped with TBI.
    It was running perfect then one morning the motor will turn but won't start.
    I have replaced the Distributor Cap, Rotor, Coil, and Electronic Module on the distributor.
    The plugs and wires are still good. And there is still NO spark.
    I also noticed that there is NO fuel going into the TBI.
    I'd appreciate any advice from anyone out here. Thanks!
  2. Big Red
    Big Red 1/2 ton status
    Jan 9, 2003
    250
    Bristol, CT
    Re: Please Help ! I\'m Confused
    <font color="red"> check plug wires for secure fit and all. make sure they're good. check fuel pressure to the tb...mine lost pressure once cus of the pump dying and gave me similar results. check fuel pump for proper voltages and what not if u find no pressure or very little. i ended up getting a new tank cus i busted the baffles in the original tank (stupid speed bumps @ 40!!! lolz!) other than that, i dunno what to tell ya. sry i can't be more helpful. </font>
  3. backcountry
    backcountry 1/2 ton status
    May 27, 2004
    916
    I alway try to start with easy things first. Eg: Clean battery posts and cables, see if I have fuel and spark. Then I check ignition switch. I then make sure that when I turn the ignition to on position that i have power to my coil. Then I'm screwed because I don't know much about TBI. LOL! /forums/images/graemlins/shocked.gif
    Do you have alot of keys and stuff on your key ring? Excessive weight bouncing around and swinging around on your ignition switch can damage it. Try wiggling your ignition switch while you try to start your vehicle. (You can even spray a little wd40 into your key slot) If this does not work, Test your ignition wire to your coil to see if it is hot. You will need to turn you ignition switch to the on position when you conduct your test. /forums/images/graemlins/peace.gif
  4. NerdBoy
    NerdBoy 1/2 ton status
    Dec 24, 2002
    429
    Southern Illinois
    Is your "service engine soon" light coming on?
    I had a similar problem once. Drove me nuts. Turned out the fusable link to the computer had broken. I figured it out, finally, when I realized that the SES light wasn't coming on when I turned the ignition on.
  5. diesel4me
    Jul 24, 2003
    17,540
    930
    Massachussetts
    I think the distributor module controls the spark and the pulse for the fuel injector--I've seen some that had spark but no fuel pulse,and fuel pulse with no spark...not saying thats what it is,but at my friends repair shop,thats the first thing he tries,is another used module(that came out of a running vehicle)--8 out of 10 times it starts right up.The only thing I dont like about his troubleshooting methods is he doesn't really dig deeper to find out WHY the module blew--usually its an original module,and old age gets the blame! /forums/images/graemlins/ignore.gif
