Please help, my truck won't hardly run
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Jonathan, Nov 16, 2001.
  1. Jonathan
    Jonathan 1/2 ton status
    Apr 14, 2001
    293
    Little Rock, Arkansas
    Please help, my truck won\'t hardly run
    This morning I got in my blazer to go to school and it started and ran just like normal, then I got to the stop sign at the end of my street it died, I thought it was just cold at first, but it didn't want to start. I finally got it to run, it ran ok at higher rpm, but at lower rpm it was like it was running on 3 or 4 cylinders. If I let off the gas it would die and be hard to start again, so I had to back up all the way back to my house with one foot on the brake and one foot on the gas to keep it going. It's been missing alot on takeoff lately and I thought it was just because my headders burnt 1 or 2 of my spark plug wires. I'd really like to get this thing running again this after noon. Thanks for any help.
    77 Blazer, 350, NP203, K&N, 31-inch Cooper Discoverers
    <a target="_blank" href=http://community.webshots.com/user/jonathandwill>http://community.webshots.com/user/jonathandwill</a>
  2. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    Re: Please help, my truck won\'t hardly run
    I think some new wires and plugs are in order, or just clean the plugs youhave. I think those dead cylinders are filling with fuel and bogging you down. Buts thats just my 2 cents
    <font color=red>Life is like a mud hole:</font color=red><font color=blue>
    When the S#!T gets deep, you have to keep moving and friends can always pull you out</font color=blue>
    55 Willy's
  3. 83ZZ502_Jimmy
    83ZZ502_Jimmy 1/2 ton status
    Feb 7, 2001
    3,103
    Richmond, VA
    Sounds like a vacuum leak to me. If the truck backfired at all it probably blew off a line. This is the most common thing for what you are describing.
    Check these and let us know
    My .02,
    John
    <font color=blue>"When all else fails, read the instructions, or get a bigger hammer"</font color=blue>
  4. Jonathan
    Apr 14, 2001
    293
    That's what I was hoping to hear, I have a new set of taylor spyro-pros on the way, they should get delivered this after noon. The vacuum line looked fine this morning when I looked at it, but I'll check again when I get home. Thanks for the quick replies.
  5. Leadfoot
    Nov 28, 2000
    3,112
    Western Massachusetts
    Get a can of carb clean and spray your vacuum lines and connections when the engine is running and idling. Also spray along the base of the carb and intake gasket near the heads. If the idle changes when you spray, you have a vacuum leak in the area you are spraying.
    See my rig at <a target="_blank" href=http://coloradok5.com/gallery/Leadfoot> click here </a>
  6. Re: Please help, my truck won\'t hardly run
    Try checking the distributor cap also.
    God has a hard on for Marines, because we keep Heaven chock full of fresh souls!
  7. rocko
    rocko 1/2 ton status
    Jul 3, 2000
    3,380
    Ellsworth, Maine
    Mine had the same symptom's last week..
    installed a new set of plug's... what a difference.. found two wire's that had dried up and became brittle around the boot's.. causing some arching..
    Today she( BB aka Baby Blazer my 89) get's a new set of plug wires..
    I haven't failed, I've found 10,000 ways that don't work. www.rocko.rockcrawler.com
  8. Anteak
    Anteak 1/2 ton status
    Nov 7, 2001
    105
    Hemet, Ca.
    I have the problem with my choke not opening all the way. I start running rich which fouls the plugs. Dose it more now that it's getting colder outside. Anyways, I end up flooding the engine. Just a thought.
  9. Jonathan
    Apr 14, 2001
    293
    Thanks for all the help. I replaced my plug wires and I think that fixed it. I didn't find any vacuum leaks. It's running a little rough, but I'm just happy it's running.
  10. White Knight
    White Knight 1/2 ton status
    889
    Ft Worth,Texas
    Hey Jown Ward your signature sign is...lets say Low Life, I just me, and no one else finds it offensive, I speak from a Christian Stand point, plus all the souls the Marines have killed most likely are filling up Hell not Heaven. No Offense intended just a remark.
    <font color=blue>Veni Sancte Spiritus
    Da Pacem Cordium
    White Knight </font color=blue>
