Please help, replacing side tank on pickup
Discussion in 'The Garage' started by Mastiff, Apr 16, 2005.
  1. Mastiff
    Mastiff 1/2 ton status Premium Member
    Jul 21, 2002
    2,755
    48
    Tucson, AZ
    This has got to be the most god awful miserable job I've done in quite some time. It seemed like it would be so easy. This is for an 86 CUCV, but the tank setup is the same as any 86 pickup.
    Anyway, here's my question: when raising the tank, how do you attach the fuel lines so they don't bind and kink up when you raise it the rest of the way? I swear I attached them (sending unit to steel lines) with very little slack and with it raised as high as possible so that my arms could barely fit in there. Even so, after raising it up (and attaching all the bolts, of course) the lines are seriously kinked up. It's like you have to have the box off the truck to do this job or something. What's the trick?
    Added: I didn't mention that I'm using new fuel line, so I have to decide how short to make them. I had to destroy the originals to get the tank down. The problem is that I'm making them too long I guess, but if I make them any shorter, I don't know how I'll get them connected. :confused:
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    i put the front bracket on and let the tank wedge up against the cab and then hook the lines up. its a PITA but its doable. the rubber lines are only about 5-6" long, any longer and they will kink.
  3. Mastiff
    Jul 21, 2002
    2,755
    48
    Tucson, AZ
    Hmm. I'll give it another shot (no choice anyway), but man is it tight in there, and I'm a skinny guy. My arms would barely fit between the tank and frame. Part of the problem is that this is a new replacement tank and the seams are sticking out further.
    I'm kind of tempted to just cut down the steel lines so they end more towards the middle of the truck, then attach longer rubber and connect it after the tank is in place.
    That, or consider this a sign that it's time to replace the box.
  4. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    lol i dunno you just do it somehow
    i always remove the frame bolts and drop tank with the brackets and straps and all i dont touch all that stuff, ever
    s-10s are real fun with the lines and hoses also, its crazy
  5. Mastiff
    Jul 21, 2002
    2,755
    48
    Tucson, AZ
    Hehe. Well, the whole point this time was to replace the tank and straps, so... Getting the straps on turned out to be a super huge PITA too. The one on the fat end of the tank just doesn't really reach. But that's another story.
    I'll figure it out somehow. I'm just all out of cuss words, I used 'em all up yesterday. :blush:
    Maybe I'm making life harder with the wormgear clamps. Do you guys use the springy ones? I'm not sure which is worse to do blind with one hand.
  6. sweetk30
    Nov 1, 2004
    25,554
    548
    horseheads , ny 14845
    try going threw the top of the frame and body area.
  7. Mastiff
    Jul 21, 2002
    2,755
    48
    Tucson, AZ
    I'm thinking this is not possible. I cut the lines down to the original length and there is just no way in hell my hands can fit up there while the lines are in reach of the steel lines. :mad:
    My wife is about to have me institutionalized because I haven't stopped cussing for two days. :blush:
    I think I'm going to give up and run about 6 feet of rubber lines over to the other side of the body where there is currently a short length of rubber already. I'll just bypass the existing steel line going across.
    I don't know why this is so much harder for me than everyone else. I've heard the CUCV frame is stouter, maybe it's taller so I have less clearance. That plus the fact that the new tank seems to be wider at the seams. :dunno:
    The idea for using more rubber hose should be fine as long as I protect it from chafing and stuff. I'll get some wire loom for the points where it crosses the frame and stuff.
  8. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    are you putting the rubber hose on the tank then trying to hook it to the truck? or to the truck and trying to hook it to the tank? i don;t think its posible to do the last one, even with the bed off.
    i use the worm gear clamps, ive never had any luck with the spring clamps.
    im a big guy and i can get my arms up over the frame and reach sending unit easily with no body lift on my truck.
    AFAIK the cucv is the same as any 1 ton frame. they both are taller than a 1/2 and 3/4 ton, but its at the bottom, not the top.
  9. DERBINATOR
    DERBINATOR 1/2 ton status
    Jan 26, 2001
    196
    YANKTON,SD
    I just put one in yesterday on an 85 1 ton creww and I think the swear words are still echoing in my shop. I don't think it is possible to put them back in. I finally cut the matal lines on the truck and ran about 12" of rubber hose to were I could get to them. DONE!!! Sit back and wash mouth out with beer!!!
  10. RootBreaker
    Nov 29, 2001
    5,118
    173
    Williamstown, NJ USA
    considering there is 8 bolts on the bed.. I would unbolt the bed and move it out of the way.... just my 2 cents.. I have done it without doing that but it is a pita!!!!
  11. pvfjr
    pvfjr 1/2 ton status
    Feb 10, 2004
    2,425
    Oakridge, OR
    That's what I did. So much easier. I'd quit wasting your time struggling and just make it easy on yourself.
  12. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,224
    94
    Stevens Pass Highway, WA
    I've always just taken the 10-15 minutes to remove the bed first. A lot easier than trying to fight all of the lines into place.
