Please help - Throttle stricking
Discussion in 'The Garage' started by Ben B., Apr 12, 2007.
  1. Ben B.
    Ben B. 1/2 ton status
    Sep 1, 2005
    352
    Central PA
    I took my truck to a well experienced mechanic who owns several lifted FS Chevs himself to see why my throttle was sticking.
    He went over my carb, cleaned it, readjusted everything, but my throttle is still sticking SO much it's reallly a PAIN. Almost undrivable.
    I think the pedal is sticking, cause once it sticks and i tap on the pedal it unsticks for a bit.
    What can I do to cure the problem? I need this fixed ASAP! [TOMORROW]
  2. K5-newf
    K5-newf 1/2 ton status
    Nov 5, 2005
    236
    canada
    spray some rust check on the cable and the where the pedal mounts, solved my problem
  3. dyeager535
    26,979
    You can also disconnect it from the carb to make sure the problem ISN'T the carb. Then you can disconnect the throttle cable from the pedal, ensuring the pedal isn't the cause.
  4. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    What he said. If the cable is not attached to the pedal, and it sticks, it is a carb problem. Not attached to the carb, and it sticks, its a pedal problem. Not attached to either and the cable sticks, its the cable.
  5. vortec
    vortec 1/2 ton status
    Jul 22, 2004
    1,472
    fort worth, texas
    warped carb putting the throttle shaft in a bind?
