Please Help...Truck wont start
Discussion in 'The Garage' started by Curtis2kul, Nov 28, 2003.
  1. Curtis2kul
    Curtis2kul Registered Member
    Oct 15, 2002
    62
    Winston-Salem, North Carolina, United States
    O.K. Went to go start my truck up the other day and it wouldnt start, so first thing i checked the battery (good) then i thought maybe the starter, so i took that off and checked it (good), do yall think it could be the ignition switch or the park/neutral safety switch?????
  2. the cork
    the cork 1/2 ton status
    Apr 20, 2003
    128
    mid west,
    check all your battery connections ground and positive,
    make sure there tight, plus try to give more info,
    does it turn over, does the ignition light come on,
    does anything happen when the key is turned, could be the
    fusible link, could be the control module, /forums/images/graemlins/thumb.gifhitchhike,
  3. Curtis2kul
    Oct 15, 2002
    62
    no, i doesnt even try to start. the radio and everything come on but when it goes to the start it doesnt do anything, im going to take the switch off tommoro and see what it looks like back there
  4. MEPR
    MEPR 1/2 ton status
    Oct 21, 2002
    1,546
    McChord AFB
    clean all the conections and tighten em up. Thats wher i would start, just start looking for loose and dirty wires.
  5. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    Fuceable link ???
  6. 99firehawk
    99firehawk 1/2 ton status
    Dec 15, 2002
    491
    You didnt say what year your truck was, or wether it was an auto ir a stick. First thing I would check was to see if there was a "crank" fuse. Then I would check for power to the small wire on the starter solenoid when the jey is turned to crank. Then I would check ign switch then neutral saftey in that order.
  7. boggerless
    boggerless 1 ton status Premium Member
    May 26, 2003
    22,728
    96
    dearborn heights, Michigan
    i think youz right boss /forums/images/graemlins/grin.gif. we have that prob with our macks at work all the time. everything works but it won't turn over. dirty cables. /forums/images/graemlins/k5.gifto /forums/images/graemlins/truck.gif
  8. 75-K5
    75-K5 3/4 ton status
    Apr 28, 2002
    5,353
    Anderson, Indiana
    I had this problem on my Jeep, and it turned out to be a bad starter /forums/images/graemlins/eek.gif
  9. k5guyva
    k5guyva 1/2 ton status
    Oct 26, 2003
    165
    Southeast VA
    How did you check the battery? Simple voltage test isn't a guarantee. You need to load test it to be sure. I agree with others that you should check the cables first.
  10. Curtis2kul
    Oct 15, 2002
    62
    i load tested it and everything, i think it has something to do with the ignitions switch because i have to take my key out in the acc position, something is wrong with it, im going to get out there today and look.
