Please Help-urgent Problem-truck Dies
Discussion in 'The Garage' started by 84gmcjimmy, Oct 27, 2006.
  1. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    I went to get insurance on the Jimmy today and it ran perfectly before I left. When I came back with the stickers and went to drive it, it stalls unless I leave my foot on the gas.
    I try to drive it, and as soon as my foot leaves the pedal to brake or put the clutch in, it dies. It's not driver error as it has never done this before.
    WHY IS IT ALL OF A SUDDEN NOT RUNNING?
    I played with the idle speed and it doesn't seem to change it at all. It has a good 1/8 of a tank of gas (more than it did before I had it running smoothly) so it cannot be gas. It stays running as long as I give it gas. As soon as I let off the needle falls on the tach and its no longer running.
    So, does anyone know why it would die like this for an unknown reason? It doesn't idle at all.
    Please help, I am seriously about to lit this on fire and be done with my troubles forever.
    Thanks in advance.
    S.
  2. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    Has it been sitting for a while? If so you probably have a float stuck or a bunch of jelly in the carb. Please give more detail about the last time it ran well.
  3. ryoken
    Jun 13, 2003
    29,624
    1,379
    Jersey Shore
    Yup, definitely a carb issue Steve...
  4. dremu
    Feb 27, 2000
    15,958
    452
    East of San Francisco
    Can o' carb cleaner and some gas-anti-freeze-dry-out stuff ... spray carb cleaner in the carb (duh), and pour the anti-freeze stuff in the tank.
    If the gas has been sitting a while, it gunks up -- this is why the others have said what they said (which is all true! :) )
    Also check the fuel filter in the carb, and then throw it away and go with a (metal!) external inline filter.
    -- A
  5. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    choke sticking perhaps?
  6. AZ79K5Project
    AZ79K5Project 1/2 ton status
    Jan 15, 2006
    2,082
    Arizona
    Were you messing with anything under the hood? Any inspection under the hood? Wondering if you had a vacume line knocked loose.
  7. Chevy305
    Chevy305 6 Lug 14bsf Status Premium Member GMOTM Winner
    Jan 23, 2006
    11,230
    488
    New Hampshire
    definately sounds like a vacuum leak...
  8. peter redman
    peter redman Registered Member
    Dec 28, 2002
    11
    duncan,b.c.
    had the same issue.turned out to be a vacum leak. used wd-40 to find it. turned out the gasket under the carb had gone bad.
  9. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    Using WD-40 to find the vacuum leak, while it is running? Does it make bubbles or what does a vacuum leak look like?
  10. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    use carb and choke cleaner spray around the carb if the engine speed changes thats where the leak is
  11. supersize75k5
    supersize75k5 OrganDonorRacing.com
    Feb 3, 2004
    8,832
    4
    gilbert az
    ive had a carb gasket do the same thing,
    well since it has spark that leaves you with a fuel or air issue
    now which one is it is the problem:D
    any whistle like sounds?
  12. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    I can't really do that because without me on the gas, the truck won't stay running. Unless I get someone to stay inside the truck with there foot on the gas...
    I will see what I can do.
  13. Clod_King
    Clod_King 1/2 ton status
    Jun 7, 2005
    1,094
    Grimsby Ontario
    use a stick, or lean a brick on the gas pedal, with another brick behind it, and just adjust the "idle" you want, and start working on the truck.
    It worked for me when I had to run the old fuel through my truck. (and yes I realize there is probably a better way to get crap fuel out of a tank).
  14. dhcomp
    dhcomp 3/4 ton status Premium Member
    Mar 17, 2001
    9,862
    291
    Truckee, CA
    I'm not a carb guy, but i would also check the fuel filter.
