Please help with these angles
Discussion in 'The Garage' started by K5Steve, Sep 19, 2005.
  1. K5Steve
    K5Steve 1/2 ton status
    Aug 10, 2005
    288
    Carson city, nv.
    I just measured my t case/driveline and pinion angles and came up with 18* for the driveline,9*up at the pinion,and 5* down at the t case.I can't figure out what they mean.It is an 88 K5 with a 700r4 and np208.It looks like a 2 1/2 inch lift with blocks in the rear and they don't look to have a taper.Do the ang
  2. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    You need to rotate the pinion down 4*
  3. K5Steve
    Aug 10, 2005
    288
    Carson city, nv.
    If I use shims woudn't that rotate it up or could I just turn them around?
  4. readymix
    May 30, 2004
    6,706
    26
    you can turn them around
  5. K5Steve
    Aug 10, 2005
    288
    Carson city, nv.
    I thought the pinion was supposed to point toward the t case.
  6. MarcS
    MarcS 1/2 ton status
    Oct 4, 2002
    515
    NJ
    The center lines should be parallel with regular u-joints and should point at the t-case when using a CV.
    See the Tom Woods website, great info. Tom Woods Go to-Tech info/Driveline Geometry 101
  7. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    After doing my shackle flip I had to rotate mine down 6*. I will weld new perches on when the 14 bolt goes in at about 5* and get rid of the shims.
  8. K5Steve
    Aug 10, 2005
    288
    Carson city, nv.
    Yeah by the pics on that website I can tell just by looking at it that the angle is off.The angle it's at now is like it would be with a cv shaft.
  9. K5Steve
    Aug 10, 2005
    288
    Carson city, nv.
    Would it make more sense to lower the t case?I have the 4*shims but figured I would see what may work best.
