Please, Helpme on 700R4 problem.
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Jaguargt, Mar 31, 2003.
  1. Jaguargt
    Jaguargt Registered Member
    Mar 14, 2003
    46
    Guatemala
    Hi, first, sorry about my bad english, i'm from guatemala, and here is my problem:
    i'm trying to adjust the tv cable, but even with the cable all released the trans doesn't shift to OD until the accelerator is totally released (i have a 6.2d), and if i barely touch it, comes the downshift to 2nd. so i'm running almost all the time in second and third gear, so i think i'm overheating the trans because the fluid it's a little dark, could be that i have a wrong tv cable (too short)?. thanx in advance.
  2. azblazor
    May 5, 2001
    1,953
    Arizona, Phoenix area
  3. TxK5Blazer
    TxK5Blazer 1/2 ton status
    Aug 13, 2000
    593
    Floresville, Tx
    i think you are on the right track. I would double check what a kickdown cable would run. I have an 82K5 with a 700r4 and i don't have any problems with it shifting. That would be my first choice... /forums/images/graemlins/k5.gif /forums/images/graemlins/pimp1.gif
  4. K5thatShmobs
    K5thatShmobs 1/2 ton status
    Sep 27, 2001
    353
    San Luis Obispo, CA
    First, definitely make sure its the right TV cable... if it is, it sounds like your cable is adjusted so that its pulling the cable out too far. Adjust it so at full throttle the cable is being pulled out of the sleeve less. If its factory version and it has a ratcheting mechanism on it, push that button in on the TV cable sleeve at the carb/throttle body end (usually right behind the bracket that holds the cable) and pull on the throttle linkage so its wide open (all the way) and you should hear it ratchet out. Then let off the button and then bring the throttle back to closed position. This should adjust it properly.
  5. Jaguargt
    Mar 14, 2003
    46
    Guatemala
    Thanx boys, i'll try with your advices.
  6. KShortell
    KShortell Registered Member
    Jun 11, 2001
    44
    Bel Air, Maryland
