please identify this 14bff
Discussion in 'The Garage' started by socal chevy, Jan 18, 2005.
  1. socal chevy
    socal chevy 1/2 ton status
    Nov 18, 2004
    308
    San Clemente, CA
    http://community.webshots.com/user/socaltacoma - chevy pics
    Part number on gears is 1 GM 327723 9 41 11 85.
    4.56???
    Detroit locker???
    Was told it had 4.56 and detroit locker...soooooo
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    it is 4.56 gears
    not sure about the detroit, it could be because it has a open carrier. :thumb:
  3. sweetk30
    Nov 1, 2004
    25,548
    543
    horseheads , ny 14845
    in the one pic you can see the big hole in the carrier assbly the gear bolt to . if there are 3 total its a cov-lock ,if 4 total it open or locker, and if 4 look in the side holes for spider gears if there is any its open. if locker you should be ably to turn the pinon and both tires turn the same way. as above 4.56 and the other # are date code for gears.
  4. sapper
    sapper 1/2 ton status GMOTM Winner
    Jul 11, 2001
    3,052
    NoVa
    I thought i saw a 41 11 on the close up, if so its 3.73s
  5. AkMudr
    AkMudr 1/2 ton status
    Dec 30, 2004
    917
    Alaska
    Good call sapper, I was just typing that up.....41 ring gear teeth, 11 pinion...41/11=3.727272 OR 3.73. With that said, its either open or GovLoc.
  6. 1977k5
    1977k5 3/4 ton status Vendor
    May 26, 2003
    9,995
    133
    The number he gives also shows 3.73 gears (41 11), not 4.56 (41 9). You can't tell by looking if it has a detroit (it would be inside the carrier). The best way to check that is to spin one tire and see if the other spins the same way or opposite. If the other tire is spinning the opposite direction the carrier is open or has a gov lok. If both want to spin the same direction it has a detroit.
  7. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    yea you can, just look and see if you can see the spider gears, if you cant and there are 4 holes on the outside of the carrier then you have a detroit.
  8. socal chevy
    Nov 18, 2004
    308
    San Clemente, CA
    dont tell me that. are you sure??!!! I was told by seller it was 4.56. damit
  9. sapper
    Jul 11, 2001
    3,052
    NoVa
    he :dunno: or at least i THINK he did
  10. socal chevy
    Nov 18, 2004
    308
    San Clemente, CA
    NOOOOOOOOOOOOO!!!!!
  11. socal chevy
    Nov 18, 2004
    308
    San Clemente, CA
    hey guys.... 9 41 11 85
    11 85 being the date of manufature..... 9 / 41 = 4.56's!
  12. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    9 41 = 41/9 = 4.56 gears
    11/85 = date of manufacture (month and year)
  13. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    Yes it is a 4.56 just like mine.
    Believe it or not everyone is going to agree with Tim on this one:yikes::yikes:
  14. sapper
    Jul 11, 2001
    3,052
    NoVa
    and people call me dumb, thats why i said i think, good call to get you the right info:blush:
  15. socal chevy
    Nov 18, 2004
    308
    San Clemente, CA
    dont feel too bad guys Tim called them as 3.73 at first.
  16. readymix
    May 30, 2004
    6,706
    26
    I did not see that.
  17. socal chevy
    Nov 18, 2004
    308
    San Clemente, CA
  18. socal chevy
    Nov 18, 2004
    308
    San Clemente, CA
    ok I got the gears worked out......now what about the D-locker?...How do I verify that?.... I am by myself, so turning wheels and what-not is kinda hard to do alone.:confused:
  19. AkMudr
    Dec 30, 2004
    917
    Alaska
    Sorry bout that, I was always told its the first 2 sets of #'s out of the last 3, the last # being the year. I dont mind admitting I was wrong.
  20. mikey_d05
    mikey_d05 1 ton status GMOTM Winner
    Nov 23, 2004
    10,453
    Minnesota
    Ummm...there's not a much easier way to figure it out. Get the brake drums and pinion just high enough off the ground to be able to turn...and give it a whirl. If it was out of a CUCV military truck then it almost def. has a detroit.
