PLEASE!!! Ignition Switch HELP!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by KRAZIE87K5, Jun 2, 2001.
  1. KRAZIE87K5
    KRAZIE87K5 1/2 ton status
    Feb 23, 2001
    3,369
    Chicago, IL
    This damn thing is getting me upset now... How do I remove a ign. switch from a column that does NOT have tilt? Check the pics below to see how far I got...
    Please guys... I am doing this freaking job as a favor for my neighbor who is in a bit of a bind. Now I have imobilized their car for them too :)
    All ideas welcome!
    <A target="_blank" HREF=http://24.10.209.54/ignassy.htm>http://24.10.209.54/ignassy.htm</A>
    <font color=red> Check out my truck @ </font color=red>
    <A target="_blank" HREF=http://24.10.209.54/bigolk5.htm>http://24.10.209.54/bigolk5.htm</A> [​IMG]
  2. shane
    shane 1/2 ton status
    May 6, 2001
    162
    Prince George, BC, Canada
    My books says to lower the steering column and the switch is mounted in the top of the column jacket, inside the channel section of the brake pedal support. Then set the switch in the lock position and remove the two mounting scews and detach the switch. This is for 1971 and later model ignition swiches. To put the swich in the lock position you will see some sort of a sliding pin?? (hard to make out the picture) you need to locate it about middle of the slide.
    I hope this helps, I have never done this so I thought I`d look at the books for you...sounds like it is a little bit involved though.
    Shane
    Never argue with idiots; They will drag you down to their level and beat you up with experience [​IMG]
  3. POWERMAD
    POWERMAD 1/2 ton status
    Mar 4, 2001
    3,466
    Oregon
    Oh boy
    YA took it down way to far.
    I take it you are taking the lock cylinder out.
    That recess that sorta looks like a big L below the cyliner has a bit of flashing that you can break out with a small screwdriver.
    Turn the key to the on position and depress the tang and tyhe cylinder will slide out.
    If you have lost the key then take it to a lock smith.
    I have drilled them out before but it is worth it to spend the $40 on the locksmith.
    Hope that helps.
    my truck's not dirty, it's earth tone paint
  4. KRAZIE87K5
    Feb 23, 2001
    3,369
    Chicago, IL
    Yup the key is lost...
    Damn...
    I took it down so far, because I wondered if the pin that held it in might be on the back side of the collar after I couldn't find one on the front.
    I guess I will have to tell her to take it to the lock smith then... Thanks for all the help POWERMAD.
  5. POWERMAD
    Mar 4, 2001
    3,466
    Oregon
    No sweat bud.
    It's a little tricky getting the sector to line back up with the rack, it just takes a little patience.
    See ya
