Please look at my brake line pic to see if they are right?
Discussion in 'The Garage' started by stallion85, Aug 29, 2006.
  1. stallion85
    stallion85 1/2 ton status
    Jul 11, 2003
    3,659
    Cedar City, UT
    I am trying to figure out which position these brake lines go in:doah: Anyone have pic's of there aftermarket lines connected to the caliper?:o
  2. stallion85
    Jul 11, 2003
    3,659
    Cedar City, UT
    Here is the only position that seems to fit right but it doesn't look right?
  3. neverendingproject
    neverendingproject 1/2 ton status
    Jul 24, 2005
    1,637
    Tulsa, OK
    I would twist it then reconnect to get it curled and off the tire.
  4. shane74
    shane74 1/2 ton status
    Feb 12, 2002
    4,100
    Vancouver, WA
    Hmmm...they look like they should be positioned so the line goes back towards the truck, not towards the front. You probably already tried that though. How were the old lines routed? What does the old fitting at the caliper look like?
  5. stallion85
    Jul 11, 2003
    3,659
    Cedar City, UT
    I was planning on it, but am still insure if this is the correct way they should be connected. It just seems like I lose a lot of length with them hooked up this way.
  6. stallion85
    Jul 11, 2003
    3,659
    Cedar City, UT
    They are towards the rear....the high steer arms make it look like they are going to the front.:o
  7. stallion85
    Jul 11, 2003
    3,659
    Cedar City, UT
    Not sure about the old lines as they were tossed a while back when I tore down the 60:doah:
  8. Jishory
    Jishory 1/2 ton status
    Jan 8, 2002
    1,367
    Palmdale, CA
    looks pretty close to mine, you can get springs from the hardware store to keep them off the tire
  9. RaisedK5
    RaisedK5 1/2 ton status
    932
    Long Beach, CA
    Mine were like that too, untill i carefully ground the lug chinga-whatsis off the caliper like so, and then could turn it anywhich way i wanted.
  10. stallion85
    Jul 11, 2003
    3,659
    Cedar City, UT
    Thanks for the quick replies, I will attach the the lines to the shocks once they are mounted up :)
  11. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,084
    486
    Grand Rapids area
    Why doesn't the bleeder face up?
  12. stallion85
    Jul 11, 2003
    3,659
    Cedar City, UT
    Is it supposed too? I don't know how they could go on to have the bleeder facing up?? I am pretty sure I have them on the correct sides:(
  13. Citizen Rider
    Citizen Rider 1/2 ton status
    May 5, 2005
    1,415
    Plano, Texas
    Edit: they are correct. 10bolt bleeders are in a different possition i beleive.
