PLEASE! No downshift from 3rd. to 2nd, OD to 3rd. Good, upshift good.
Discussion in '1982-Present GM Diesel' started by Jaguargt, Aug 6, 2003.
  1. Jaguargt
    Jaguargt Registered Member
    Mar 14, 2003
    46
    Guatemala
    i just install a recently rebuilt 7OOR4, and everything seems to be fine, upshift very good, and the downshift from OD to 3rd is nice, but from 3rd. to 2nd. doesn't happen almost ever, even doing it manually, but sometimes it does the downshift, could be a wrong assembled valve body?, because this is the only problem of the trans, thanx.
  2. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    I am no expert on the 700 but I believe it's the TV cable that needs to be adjusted.
    There are some threads on the 2nd gen forum that I have seen explain how to adjust it, do a search, you might get the answer before anyone reads your post. /forums/images/graemlins/thumb.gif
  3. Tybee
    Tybee 1/2 ton status
    Mar 25, 2001
    1,565
    Centennial, CO
  4. Jaguargt
    Mar 14, 2003
    46
    Guatemala
    thanx, but if it was a wront Tv cable adjustment, i would be able to downshift manually?, and i can't from 3rd. to 2nd., that's why i think could be some problem in the valve body?. thanx.
