please settle a bet for me. twin stick 205?
Discussion in 'The Garage' started by SCOOBYDANNN, Nov 9, 2004.
  1. SCOOBYDANNN
    SCOOBYDANNN 1/2 ton status
    Sep 4, 2001
    2,131
    26
    El Paso, TEXAS
    what is the purpose of twin sticking a 205. I think i know what is right but i want uncohersed answers first.
    thanks
    and a case of beer is riding on this.
  2. atho
    atho 1/2 ton status
    May 14, 2003
    1,115
    Wayne County, Ohio
    to be able to independently control each axle in either Low or High range is the quick answer.
  3. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    It give you crazy options.
    2H
    4H
    N
    4L
    2H rear only
    2H front only
    2L rear only
    2L front only
  4. SCOOBYDANNN
    Sep 4, 2001
    2,131
    26
    El Paso, TEXAS
    damn--were were both right. but ill ask this--how do you get just 2L.
  5. bigblock44k5
    bigblock44k5 1/2 ton status
    Jun 8, 2003
    396
    Hurlburt Field, FL
    To make it simple, each stick works a rear. 1 stick works front, the other works the rear. Drive around normaly with front in neutral and rear in HI. For 2wheel LOW just leave front in neutral and put rear stick in LOW, viola.
  6. tRustyK5
    Jul 23, 2000
    36,181
    1,388
    E-town baby!
    It's more a manueverability thing. Front wheel low range, E-brake, turn wheels and it'll pivot on the rear tires and turn tighter.
    Rene
  7. Greg72
    Mar 5, 2001
    15,684
    1,392
    642 Days to BB2018
    It's so that people can accidentally put one axle in 4H, and the other in 4L and blow the gearsets out of their axles.
    Twin-sticking was developed by Genuine Gear as a way to increase their revenues.......
    /forums/images/graemlins/rotfl.gif
  8. Blazr77400
    Blazr77400 1/2 ton status
    Aug 31, 2001
    652
    Ogden, UTAH
    Or to let somebody try to modify the shift rail and grind to much letting it go into front wheel high and rear wheel low and spending another 4 hours welding and grinding to fix it.(luckily it was my brothers, I did it to mine first no problem, so I thought I could wiz through his)
  9. pvfjr
    pvfjr 1/2 ton status
    Feb 10, 2004
    2,425
    Oakridge, OR
    Any resources on this process?
  10. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    The purpose is to pretend you have a Dana 300.
    Once a low gearset is out for the 205 this will be even more true. /forums/images/graemlins/rotfl.gif
  11. mcinfantry
    mcinfantry 1/2 ton status
    Dec 2, 2003
    308
    Rene
    correct. offroad i can turn my truck sharper than a stock blazer. and thats with a electrac (limited slip) in the front
  12. spoolnaround
    spoolnaround 1/2 ton status
    Apr 8, 2002
    1,419
    Kingsburg Ca
