Please tell me about manuals...
Discussion in 'The Garage' started by ugly_blazer, Jul 14, 2004.
  1. ugly_blazer
    ugly_blazer 1/2 ton status
    Apr 12, 2004
    1,214
    Ever since the hydro clutch post a few weeks ago I have been thinking about switching from an auto to a manual. I know nothing about working on manuals. To remove one from a vehicle, do I just unbolt the transmission, then unbolt the bellhousing from the motor, and then the clutch and pressure plate?
    I want to find either a 465 or 4500(?)(OD would be cool), but it has to be from a 2 wheel drive truck. What is the approximate length of the bellhousing and transmission from the front to the rear output yoke? It has to be shorter than a long shaft 2 wheel drive th350 to work for me. Do they have fixed yoke or slip yoke, 465 and 4500? Is there any certain years or spline counts better than others? I will want a hydro clutch. Any info is appriciated /forums/images/graemlins/ears.gif
  2. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    You'll need a 85/86 chevy fro the donor inorder to get the hydro set up. You'll need the bellhousing and tranny, might as well put a new clutch in when ya swap it.
    Why you using a 2wd set up?
    the 465 is the shortest tranny chevy had. my 465-205 is 4" shorter then a 350-203.
    my brother is swapping to a 2wd th400 in his cause his co worker runs a 2wd 465 and they both have dodge 205's devorced behind them.
  3. RootBreaker
    Nov 29, 2001
    5,117
    173
    Williamstown, NJ USA
  4. ugly_blazer
    Apr 12, 2004
    1,214
    I have the divorced 205 Dodge case also.
