please tell me
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by **b**, Jun 12, 2001.
  1. **b**
    **b** 1/2 ton status
    279
    KIllington, VT.
    a new noise on my 87
    110K on it
    a clicking noise/ rattle almost as if the disc brake pads were rattling (kind of a sound)
    only when light on the accelerator ...
    no sound when i rev the engine in "N" the clicking is consistant with the motor rpm as far as i can tell...
    could this be UV joints ???
    again, please tell me ...
  2. riz
    riz 3/4 ton status
    Mar 7, 2000
    6,026
    Wisconsin
    <font color=purple> It could be a few things ........... front hubs going south on you, maybe u joints or even connecting rod bearing that's fried .......... let us know what you find out.
    good luck, hopefully it's just your hubs, if they're automatics it would be a blessing........ put in new manuals ..... WARN premiums are a nice and easy upgrade.
    L8r,
    . Riz . <A target="_blank" HREF=http://www.geocities.com/rizmonkey>http://www.geocities.com/rizmonkey</A>
  3. muddin4fun
    muddin4fun 3/4 ton status
    Feb 19, 2001
    5,644
    N Texas
    Do you have an idea of where it's coming from (front, back, passenger front side, etc)?
    <font color=purple>Have you hugged your K5 today?</font color=purple>
  4. **b**
    279
    KIllington, VT.
    thanks for the prompt response there Riz
    but i did away with the auto hubs about a year ago
    and went with the WARN Standards...
  5. WOODYJ
    WOODYJ 1/2 ton status
    May 5, 2000
    144
    I had one that sounded like that. I looked all over to find it and finally found a broken flexplate on the front of the torque converter. I hope that is not what is wrong. It is kind of the pitts to change. Might check it though!!
    k5woody I Don't Understand The Jeep Thing Either!!!
  6. **b**
    279
    KIllington, VT.
    not too sure as of yet i need to get another body to either drive or hang their head out the door ...
    to determine exactly where the sound origin is
    but believe me iam on it ...
  7. Boss
    Boss 1/2 ton status Author
    2,550
    Maryland
    Is it a ringing/rattling sound??
    Could be something as simple as an exhaust shield got rusted loose, and is just rattlin away. They're annoying, but harmless. There are exhaust shields everywhere...under the spark plugs, down at the pipe after the exhuast manifold, above the cat, above the muff....etc.
    Boss
    <A target="_blank" HREF=http://www.boss.coloradok5.com>http://www.boss.coloradok5.com</A>
  8. Bondo
    Bondo 1/2 ton status
    193
    Bath, NY
    I had the same problem as K5woody. Sounded like something clicking or rattling. Thought it was the catalytic convertor sheild but finally found out it was a cracked flex plate.
    [image]http://dopey.alfred.edu/~bondo/bondo.gif[/image]
    BONDO WILL FIX ANYTHING!!!
  9. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Probably the front pump knocking in your 700R4. That's very common and it makes a very annoying clicking sound. That might also be what cracks people's flexplates all the time.
    Tim
  10. **b**
    279
    KIllington, VT.
    pretty sure its the flex plate...
    whats a ballpark figure on getting this fixed?
    with 110k on it should i rebuild the tranny while its out
    funds are tight... but thats what plastic is for
  11. 89Blazin
    89Blazin 1/2 ton status
    Mar 20, 2001
    134
    midwest KC area
    I would guess around $250 to get the flex plate replaced, depending on where you live. As for the tranny, why rebuild if it's working OK? Tranny rebuilds run from $600 to $1600 depending on the model.
    85 Burb and an 89 Blazer
    One just for fun, one simply for pleazer
