Plow?????
Discussion in 'The Garage' started by trouble1, Oct 28, 2002.
  1. trouble1
    trouble1 1/2 ton status
    Sep 28, 2002
    346
    travelling, probably lost
    I found a cool house that I can afford to rent up here, but there is a problem...Id have to attatch a plow to the front of my Blazer. The house is on 35 acres and its a longgggg private road to access. Heres my question...what all would I have to do to the suspension to hold it up. I've got the stock 2 leaf suspension w/ add a leafs and a 3" body. I have the add a leafs for the height I want though. Also, when I dont have the plow on it, I would not want the front aiming at the stars. I'm lost here...any advice would be helpful...Thanks /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/k5.gif
  2. willyswanter
    willyswanter 1/2 ton status GMOTM Winner
    Dec 24, 2000
    2,690
    Bakersfield, CA
    Air bag assist /forums/images/graemlins/cool.gif When you put the plow on, fill the bags up with 50 or 60 pounds of pressure, when you take it off, let the air out.
  3. sapper
    sapper 1/2 ton status GMOTM Winner
    Jul 11, 2001
    3,052
    NoVa
    or just put on some air shocks. Gabrial makes them
  4. trouble1
    Sep 28, 2002
    346
    How will either work for wheeling???
  5. landsmasher
    landsmasher 1/2 ton status
    Mar 13, 2002
    4,423
    California, The Blow Me State
    Seeing as how you have stock springs in the front, use air shocks. That way when you have the plow off the truck, when you relieve the pressure from the air shocks you will be at stock height and the shocks will work like normal. Will do nothing to your wheeling abillities... My friend up in June Lake has done this with his furd pickup and it works great... Get the best you can find and don't spare expense...
  6. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    For eight years, my suburban ran with the stock two-leaf front springs and a 7 foot western plow/plow mount. I don't see why you should be concerned with your planned setup. Yes when the plow is on and up, the front end dives a bit, but the plow is usually detached (no snow) or lowered (when parked). I now have a 4" rough country lift and still have the plow on it. Any more questions for me, just ask.
  7. bigjbear
    Feb 18, 2000
    13,973
    453
    Marietta GA
    My dad ran the stock springs on his plow truck for years w/ no prob. If they are worn out it might sag bad, but otherwise, no worries. As far as off-road, the plow subframe hang down below the bumper.
  8. DieselDan
    DieselDan 1/2 ton status
    Jan 27, 2001
    1,056
    Vermont
    Your headlights are blocked by the plow when you're driving around. The plow lights are aimed correctly with the plow lifted for road travel.
  9. jimmy88
    jimmy88 1/2 ton status
    Feb 17, 2002
    351
    Detroit, MI area
    Used a 7-1/2' meyers for many years now with 2-1/2" skyjacker front springs, first on the Burb and now on the Jimmy, with no problems. It doesn't dive much at all with the blade up. Made my own relatively quick install/remove lower mount for the blade and only put it on when it snows, so there's no wheeling problems (forget about wheeling with it on). Looks like there are some pretty nice newer mounting systems out there that may be wheeling friendly.
