Plowing suspension?
Discussion in 'The Garage' started by kustom71, Dec 8, 2003.
  1. kustom71
    kustom71 1/2 ton status
    Mar 14, 2003
    117
    NJ
    Anyone plow with thier k10 full size?If so what if any mods to suspension or front end have you done?Not really looking for a lift kit but i would guess you would something more Heavyduty.Thanx /forums/images/graemlins/truck.gif
  2. Fry
    Fry 1/2 ton status
    Sep 5, 2002
    400
    Sask, Canada
    I don't plow but I know air bags would help out greatly on the front, just air them up when you have the plow on, when its off just let some air out so it won't be too stiff. It would be a pretty easy solution. Around $60 a bag, some air line and some brackets for $50 and just use schrader valves (valve stems).
  3. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    I plow with my 'burb. Before I put my lift on, it had the stock, 2-leaf spring pack, nothing else. Now I've got 4" lift springs that are pretty stiff, so I didn't feel the need to do any mods to make it ready to plow. One thing is, you can definitely see the frontend (even with the stiff front springs) go down an inch or two with the plow up. So, keep that in mind for tire size selection, but I don't see the need for further beefing. If you do lots of driving on the road with your plow up, first of all, your tranny (if it's an auto) will hate you, and secondly, you might want to think of double shocks up front to reduce the bouncing you'll experience when you hit bumps.
  4. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    And for God's sakes, lower your plow when you park!!!!
  5. heavy4x4
    Aug 28, 2002
    3,270
    YES! /forums/images/graemlins/deal.gif Good point. /forums/images/graemlins/thumb.gif
  6. ben427
    ben427 1/2 ton status
    Mar 10, 2002
    1,123
    Waverley, Nova Scotia
    This sounds pretty grotey, but i use those coil over load helping shocks in the front of mine, does a fine job and doesnt hurt the ride to bad in the summer.
  7. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    There really are few things that piss me off more than seeing a truck parked with the plow up.
  8. tecton
    tecton 1/2 ton status
    Dec 1, 2002
    1,553
    WV
    dad plowed with a scottsdale k10 for 5 years stock suspension, no problems whatsoever...pushed 3 feet of snow up hill no worries /forums/images/graemlins/smile.gif
  9. gravdigr
    gravdigr 1/2 ton status
    Apr 15, 2003
    1,129
    Tyrone, PA
    ALso don't forget when driving a distance with your plow up that it blocks most if not all air blowing in through the grill. Our '79 ford had some terrible overheating probs on the highway with the plow attached. It has the stock suspension but we had to beef up the cooling system.
    I also learned my lesson when parking on soft ground lower the plow onto a pair of 2x4 blocks. I parked one time in the yard after a thaw and when we needed the plow again the blade had sunk and frozen to the ground /forums/images/graemlins/rolleyes.gif
  10. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    you could always get the stock 3 leaf springs. got that on the k5 and it rides like a sombitch /forums/images/graemlins/deal.gif. my plow truck has just the 2 leaf spring and it is a little bouncy up front but not bad enough
