plug gapping
Discussion in 'The Garage' started by unick, Jan 2, 2004.
  1. unick
    unick 1/2 ton status
    Aug 16, 2003
    4,286
    San Diego Comufornia
    I got some new plugs and they are gapped to .045. Is this gonna be a problem or shouold I move them down to .035? Also how do I regap them? Do I just bend the tip down?
    LMK
    Nick
  2. unick
    Aug 16, 2003
    4,286
    I just looked on the AC Delco website and they say NOT to gap rapid fire plugs. So now I know and so do you. /forums/images/graemlins/thumb.gif
    Nick
  3. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    If its for your 87 TBI. Gap them at whatever the emission sticker in the engine compartment says the plug gap should be.
    I gap my TBI plugs at .050 but I have a pretty hot ignition.
    Most stock TBI ignitions will work anywhere between .035 and .045. Sometimes Gapping the plugs to the wide end of the range helps gain a little fuel MPG.
    And Yes. Just bend the electrode to gap them.
    Just saw your second post. didn't know they were Rapid Fires.
    Yeah you aren't susposted to re gap Rapid fires or Platinium plugs either. The guage can break the center electrode unless they are gapped with a round wire guage using care not to nick it.
  4. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    you want .045 with all stock HEI anyways, so.,., although some of the 1975 engines(mainly oldsmobile) called for .060" gap, that was first year of the HEI system
  5. dyeager535
    26,975
    Early HEI Olds were .080", then it was moved down to .060" until the end of the olds V8, 1990.
    Some GM V8's (I think it may have been the HO 305's, not 1975 IIRC) also gapped at .060" for one or two years, but then dropped back to the "typical" .035"
    Why Chev gaps that small I'm not sure, but the coil that runs a .060" gap and .035" are the same AC Delco part. I ran my 1974 SBC 350 at .060" for quite some time, and noticed no advantage or disadvantage, FWIW. Obviously there are pros and cons to wider vs. narrow gaps, but I didn't notice one either way.
  6. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    gapped my 86's carb'd 350 plugs at .057..
