plug heat range numbers,. ac delco
Discussion in 'The Garage' started by R72K5, Aug 26, 2005.
  1. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    which ones hold heat more than the other, 45's or 44's ?
    ac delco plugs*
    what should i run in an 84 229 v-6 ?
    i need to pull a coupe plugs and check and see if theyre black or gray or tan or whatm, but im almost positive they will be black, so it would need hotter plug,
    whatever is hotter numbers
    hum,.
    thanks
  2. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
  3. diesel4me
    Jul 24, 2003
    17,561
    942
    Massachussetts
    higher #s hotter...
    He right--a R43TS plug is colder than a R45TS plug..the 229's used R45TS in most cases just like a small block V8..the hottest plug in that heat range would be a R46TS...you might be able to use extended gap plugs that reach further into the combustion chamber(like R46TSX) but the also might touch the pistons,and the wider gap (.060-080) is more likely to misfire under load,or when oil fouls them..if you need hotter than R46TS plugs,a "nonfouler" with "normal" (R45TS) plugs might work better if they oil foul quickly.. :crazy:
  4. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    i wonder if stock 229 pistons are dish or flat
    hmm
    ill most likely put r45tsx in this one then it sounds like
    and run 040 gap though
    and go from there
    im sure the plug sin it now are old and nasty
    it does run pretyt damn good now all other than some cold stumble but i know that the electric choke coil is dead it doesnt shut all the way when cold and it doesnt open ujp alot when warmed up either, jut barely enough to get it off the fast idle cam step
    so im gonna put a new electric choke unit on the carb soon too.
    thanks
