plug next to vent window
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by LKJR, Aug 14, 2001.
  1. LKJR
    LKJR 1/2 ton status
    Apr 18, 2000
    2,116
    Lubbock, Tx
    ok question #678 I've got these little blue plugs in a hole on each door next to the vent window. what is this hole access port? I don't remember having it on my other truck I had.
    Like em big and topless
  2. Ressurection
    Ressurection 1/2 ton status
    May 9, 2000
    360
    Prairie du Sac, Wisconsin
    Les, this may be a long shot, but is it possible that it's a northern truck that may have had Ziebart rustproofing, or something similar? I seem to remember rustproofers using blue or yellow plastic plugs where they drilled before spraying. Just a guess.
    "High compression engines take longer to start!"
  3. harry
    harry 1/2 ton status
    Feb 9, 2001
    106
    san diego, CA
    I thought 71-72 had a hole where you described with a screw in it for window support???
    harry
    69k5
  4. BluThndr71JMMY
    BluThndr71JMMY 1/2 ton status
    May 12, 2000
    152
    Tucson, AZ
    I always wondered what those plastic plugs were for, myself. I've got '68 and '67 Chevys and the door sill is smooth on them. Vent window pivot tension, perhaps?Who knows?
  5. LKJR
    LKJR 1/2 ton status
    Apr 18, 2000
    2,116
    Lubbock, Tx
    beats me, I haven't pulled the panel off to check the inner side of the sheetmetal for rust proofing, the blazer was built in st. louis so who knows
  6. blazer72
    blazer72 1/2 ton status
    Apr 13, 2000
    939
    KCMO
    I think most were built in St Louis is the plug on the inside about 3 inches under the vent window?
  7. BluThndr71JMMY
    May 12, 2000
    152
    Tucson, AZ
    Mine was also made in St. Louis!
  8. LKJR
    LKJR 1/2 ton status
    Apr 18, 2000
    2,116
    Lubbock, Tx
    don't think it's 3" is more like 2 or so it' right on that ridge area, I'll get a pic when I can but I don't have a digi camera right now so.......
