Plug on the back of slip yoke...
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 89GMCSuburban, May 13, 2003.
  1. 89GMCSuburban
    89GMCSuburban 1/2 ton status
    Nov 15, 2001
    3,005
    Thornton, CO
    The plug on the back of my slip yoke is leaking. Can I seal this up myself with some JB Weld, or should I just take it to the driveshaft shop?
  2. 88K5Jimmy
    88K5Jimmy 1/2 ton status
    Jan 10, 2001
    1,323
    Tulsa OK
    Mine was doing the same thing. There was a big blob of rtv on the outside of the yoke. I took it to the driveshaft shop and they said they couldn't replace that plug, so I ended buying a new slip yoke. Somethimes you can get them to reseal other times you can't. Mine was throwing fluid all over the underside of my body so I just replaced it.
  3. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    A little trick that maybe most people wouldn't think of is to install a concave freeze plug there. It can be done, I have done it several times for customers.
  4. 87sm465np208
    87sm465np208 1/2 ton status
    Aug 28, 2002
    1,114
    illinois
    that is a really good ideaa, what size freeze plug did you use.? /forums/images/graemlins/grin.gif
  5. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    I don't recall what size it was. I just measure the yoke when I need to do one and then choose the correct size.
  6. 89GMCSuburban
    Nov 15, 2001
    3,005
    Thornton, CO
    Thanks for the advice guys! Local driveshaft shop welded all around the plug, changed U-joints, and re-balanced and painted it for $83! /forums/images/graemlins/thumb.gif
