Plug/sensor on vac pump
Discussion in '1982-Present GM Diesel' started by 75-K5, Mar 8, 2007.
  1. 75-K5
    75-K5 3/4 ton status
    Apr 28, 2002
    5,353
    Anderson, Indiana
    Anybody know what the 2 prong plug on the vacuum pump is? I am hopeful it is for a tach, but I highly doubt it.
    If it's useless, I'm going to throw out the vac pump and find a "dummy" plug with the shaft to run the oil pump and that's it.
  2. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    I have seen one with the electric switch, and it was going to the TPS, I don't know what it does though.:confused:
  3. 75-K5
    Apr 28, 2002
    5,353
    Anderson, Indiana
    That brings up a good point, do I need the TPS hooked up if running a sm465?
  4. imiceman44
    Aug 5, 2002
    15,160
    Sacramento, CA
    Running the 465, you will not benefit from it and if you don't have A/C you won't need the vacuum altogether.
  5. 75-K5
    Apr 28, 2002
    5,353
    Anderson, Indiana
    Good, thanks for the info. I will leave TPS disconnected and probably look for a block-off plug that runs the oil pump only in place of the vac pump shaft.
    P.S. I will get with you shortly on the firewall filter.
  6. imiceman44
    Aug 5, 2002
    15,160
    Sacramento, CA
    Where the pump goes, there is a block of plate when they don't use it.
    I think I might have an engine that has it.
  7. 75-K5
    Apr 28, 2002
    5,353
    Anderson, Indiana
    I've been reading about a vacuum actuated wastegate. Do the GM-3 turbos have this? If so then I will need to keep it installed I guess.
  8. imiceman44
    Aug 5, 2002
    15,160
    Sacramento, CA
    I( wanna say no, the gm5 and gm8 I know have a waste gate but I think GM3 didn't but if you have it already take a look. :D
  9. BKinzey
    BKinzey 1/2 ton status
    Jan 13, 2006
    3,145
    Hollywierd, CA
    The GM-3 is a mechanical wastegate. GM-4 and above are vacuum.
  10. 75-K5
    Apr 28, 2002
    5,353
    Anderson, Indiana
    Well I do have it but I have no clue what the hell I'm looking at :rotfl: I thought I had heard something about the GM3 not having a true "wastegate" but wasn't sure exactly what that meant. So I won't need any type of actuator for the wastegate at all?
  11. imiceman44
    Aug 5, 2002
    15,160
    Sacramento, CA
    Well BKinzey says it's mechanical so there no need for your intervention it just releases when it get's to a certain pressure.
