Plug wire orientation
Discussion in 'The Garage' started by afroman006, Jul 21, 2003.
  1. afroman006
    afroman006 1/2 ton status
    Aug 21, 2002
    2,876
    My burb's been vibrating and a few people told me to check and make sure the plug wires are in the correct location. I've looked my Haine's manual over and cannot locate a diagram that tells me which wires go to which cylinder. Anyone know of such a diagram? A page number in the Haynes manual will work too. Its just one of the thing I'm going to check tryin to sort the vibrating issue out. Thx
  2. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    Check the firing order. The p/wires can go on the distributor with #1 starting anywhere you want, as long as they stay in order from there on out....
  3. Don
    Don 1/2 ton status
    May 30, 2002
    1,778
    Spokane Washington
    #1 is just 2 position's counterclockwise of center, then just follow the firing order, 1 8 4 3 6 5 7 2 clockwise. /forums/images/graemlins/grin.gif
  4. 79Stomper
    79Stomper 1/2 ton status Premium Member GMOTM Winner
    Mar 4, 2004
    4,225
    19
    Forest, VA
    Bringing this one back from the great beyond?
    Is this true? That it doesn't matter where the plug wires starta s long as they are in order? I know about the firing sequence and such, but I have a modified distributor and where the shutter wheel lines up with the hall effect sensor, the rotor is pointing at my #2 cylinder and hell if I can just rotate all my wires one over then hell that will solve all my problems, well I will have to still turn the distributor 180* back since I did this today during my trouble shooting phase of operations............
  5. sweetk30
    Nov 1, 2004
    25,526
    526
    horseheads , ny 14845
    i had a ford ranger 2.9 one time and the distributor was 180 off and what a pain in the a$$ to get to so just put wires on 180 off and 100% fixed and better.
  6. 79Stomper
    Mar 4, 2004
    4,225
    19
    Forest, VA
    Yeah I remember my Ranger and screwing around with the distributor on that blasted thing was a PITA.
