plug wires are burning up
Discussion in 'The Garage' started by mtn. burb, Jun 6, 2004.
  1. mtn. burb
    mtn. burb 1/2 ton status
    May 13, 2004
    1,260
    Ojai Calif.
    I have high heat resistant sheaths around some of my plug wires to keep them safe from the JBA headers and they are arcing (sp?) again! /forums/images/graemlins/angryfire.gif /forums/images/graemlins/angryfire.gif Need wire protection ideas.
  2. Tweetysuarus
    Tweetysuarus 1/2 ton status
    May 25, 2002
    2,294
    Lynnhood,WA
    Use the Accel shorty plugs header plugs, they will give you just enough clearance for the boots to clear the head tubes.
    Bill
  3. dyeager535
    26,979
    If you aren't running them already, would 90* boots help?
    I just put Accel "build them yourself" wires on my truck, and it is much better than trying to use ones from another application. 4041K (IIRC) gets you black accel do it yourself wires with 90* boots for HEI. For remote coil applications you have to cut the boot for the cap connector off about an 1/8", since the small cap setup uses shorter terminals than coil in cap distributors.
  4. 79Stomper
    79Stomper 1/2 ton status Premium Member GMOTM Winner
    Mar 4, 2004
    4,225
    19
    Forest, VA
    I am running a set of Dynomax headers with full size plugs and the accel high temp boots. Haven't had any problems from mine. Been on for around a year so that is a record for plug wires on the truck with the headers.
