plug wires...preferances?
Discussion in 'The Garage' started by broncoman6524, Apr 22, 2007.
  1. broncoman6524
    broncoman6524 1/2 ton status
    Oct 31, 2005
    2,469
    chuluota Fl
    this has prob been covered 100xs but is there necessarily a "better" plug wire? i bought a set of accel 8.8s wheni put my new motor in about 5000mi ago...and when i put headers on i forgot to rearrange tehm and its burned 2 of the wires.
    any preferance? ive heard that ac-delcos are the best...but idk
    if it matters its a sbc with msd
  2. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    I like Taylor spiro pro wires. Work good for me. I run them on my hot rod and my k5 They take a lot of heat and Hold up to headers well.
  3. mo
    mo 1/2 ton status
    Jun 29, 2004
    542
    Folsom, CA
    i've run msd wires fore some time now, always had good experience with them
  4. 4X4HIGH
    Dec 14, 2001
    22,063
    71
    Pleasanton, CA.
    MSD all the way, never had a failure with them yet. The 1200* boots are nice too if you have headers and the wires are close to the pipes.
  5. mrk5
    Apr 20, 2004
    12,351
    1,051
    Northern Colorado
    I second the Taylor Spiros. I had one fall against some ceramic coated headers and didn't get burned up even though the wire sat on the headers for a good amount of time.
  6. JEBSR
    JEBSR 1/2 ton status
    Dec 23, 2004
    1,541
    Clarksville, TN
    X3, put the heat sleeves on them and they will likely outlast the vehicle they are on.
  7. 83ZZ502_Jimmy
    83ZZ502_Jimmy 1/2 ton status
    Feb 7, 2001
    3,103
    Richmond, VA
  8. dyeager535
    26,982
    191
    There are certainly differences in plug wires. Whether you "need" 8.8 wires or not, the materials used to construct the sleeves and boots can vary quite a bit between manufacturers.
    I've seen the boots turn to mush in a stock application (parts store cheapies) while my accels (which don't seem to get good reviews from most) have held up for a couple of years now with header, no problem.
    Reason I went with Accel is because they (at the time) seemed to be the only company that made build your own plug wires in subdued colors.
  9. bigjimmy82
    bigjimmy82 1/2 ton status Premium Member
    Dec 9, 2005
    362
    11
    New Albany, IN
    I got a set of summit wires on e-bay for cheap, I think they are 8.5mm and seem pretty nice, and work better them my old bosch 8mm wires
  10. MNorby
    MNorby 3/4 ton status Premium Member GMOTM Winner
    Dec 10, 2001
    6,127
    57
    Powell, Wy
    I have the summit blue build yourself to length wires. I also got those clamp down retainers and made them just perfect so they are nice and out of the way.
  11. LEEREED123
    LEEREED123 1/2 ton status
    Jun 29, 2006
    384
    BFE, Ga
    I love my MDS stuff!
  12. 1977k5
    1977k5 3/4 ton status Vendor
    May 26, 2003
    9,996
    134
    I have MSD wires and they have contacted the headers many times with no damage. That is my recommendation.
    The MSD and Taylor wires are pretty much top of the line.
  13. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    Yup, Msd, then Taylors... For stockish stuff, AC Delco.. I'm not a fan of Accel's offerings...
  14. 76zimmer
    76zimmer Flyin Rat Premium Member GMOTM Winner
    Nov 14, 2005
    23,034
    1,349
    Kzoo, Mi
    I know your not Paul, but my Accel 300+ have performed very well for the last 3 years on my toy. Two of them are really close to the headers, and are holding up great. I originally went the Accel route because I'd seen people in the Drag world having problems with boxes from MSD. I also liked the dial in rev limiter of the Accel box. Although once you figure out where you want it, a plug in like MSD has would be just as good. I've pretty much left it a 6800 and called it good.
  15. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    Ah, ok, thats a vote for Accel finally getting there chit back together in recent years.. 5 to 10 yrs ago they where, bleh...
    They're gonna have to prove it to me, they mostly certainly where a company living off their name for awhile, much like Champion plugs, which still suck, and Hooker headers, tho they've got their ch*t together for awhile now...
  16. Dafey
    Dafey 1/2 ton status
    Feb 10, 2007
    2,675
    Roswell NM
    The Summit wires look just like the Taylors,they even have the same description on the Summit site.I hope there close to the same,I just bought a set LOL
  17. broncoman6524
    Oct 31, 2005
    2,469
    chuluota Fl
    are these the spiro wire yall are talking about? they seem kinda cheep...
    http://store.summitracing.com/partdetail.asp?autofilter=1&part=TAY%2D74202&N=700+4294908216+4294908395+4294840140+4294925143+4294839064+4294889567+4294889107+400235+4294849658+115&autoview=sku
    on summit's site. it says assembled/unassembled. if i pick ones that are for a sbc...ar ethey already precut to the correct lenghts for a sbc? or...are they all one length?
    these are kinda noobish questions but about what diameter would be best for my motor? sbc30 gm crate 290hp. hei, msd box.
  18. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    At work we were building a spark ignited diesel fueled 2 stroke for a military application. Weird, huh? Well, it runs! However we kept running into ignition electrical noise screwing with the injection and spark electronics (Motec + M&W). Had an RFI/EFI specialist consultant Electronics Engineer come out & consult on it. We were doing everything the way it should be. He didn't find anything that made him question it.
    So we tried MSD wires (in place of the garden variety Taylors) as I've always had good experiences with them. They let me down. They sparked just fine, but we still had a noise issue. Then we tried some Magnecor wires. They ended that problem. Since then I recommend them for the difficult situations. Top shelf components.
  19. Thunder
    Jul 20, 2000
    8,946
    Northeast Nevada
    8 MM is fine for your motor. The sets come pre cut and fit no problem.....
    But if they seem cheap to you just go ahead and spend 80+ bucks for a set of MSD. They are good wires too.
  20. broncoman6524
    Oct 31, 2005
    2,469
    chuluota Fl
    i didnt mean cheap like bad quality i was just expecitn like 60+ i did look on ebay first though...theyre like 30.
    ill prob get a set from summit, ive got more stuff i need to order from there anyways.
