Plugs and O2 sensor??
Discussion in 'The Garage' started by Jays Beast, Jun 28, 2003.
  1. Jays Beast
    Jays Beast 1/2 ton status
    Aug 7, 2002
    538
    Chandler, AZ
    Ok, bought a set of Headman Headers. Going to install new plugs and o2 sensor, what brand plugs are you guys using? and should I go with acdelco or other brand o2 sensor? /forums/images/graemlins/thinking.gif
    Thanks Jay
  2. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    A/C, and A/C....
  3. K5Jimmy
    K5Jimmy 1/2 ton status
    Sep 21, 2000
    1,141
    Lake Dardanelle/Logan Co, Ark
    I second that...Delco..
    I just went thru an experience with a New bosch O2 from Autozone that was flat lined right outta the box....there went $46
    Replaced it with a Delco ($41) and passed inspection...
    of course by this time I had to pay for a Diagnostic ($75) to find the bad O2, and an additional $30 for the third go round with the inspection Nazis....
    I figger Bosch cost me $110.... /forums/images/graemlins/angryfire.gif
  4. Suburbanite
    Suburbanite Registered Member
    Dec 1, 2001
    74
    Florida
    We installed Bosch Super Cu (Copper) HR-9-BC's in my nephew's '93 K1500 Z71 Sportside back on 10/12/02 & 172K miles. Now at 189K & they still seem to be working ok.
    Installed NGK UR5's on my '95 K2500 Sub with 132K miles last wknd & they also seem to be working fine.
    Just some alternatives to AC-Delco.
    Haven't replaced any O2 sensors yet so can't offer any advice on them.
    Here's a FYI: O2 sensors are available in heated & non-heated versions. The heated versions usually? have more wires -- 3 or 4 vs 2 for the unheated version -- and AFAIK are only used on 'newer' OBDII vehicles. Heated versions are also ~twice the price of unheated versions.
    Good luck.
  5. MousePowrd
    MousePowrd 1/2 ton status
    May 7, 2003
    215
    Saginaw, MI
    Always use AC O2's on GM engines, Bosch's usually wont throw a code if they are bad for some reason.
    I always use AC R43TS plugs. I use on the K5, Buick, and the 454 in my boat. They are great plugs
  6. ChevyCaGal
    ChevyCaGal 3/4 ton status
    Dec 16, 2000
    8,158
    Sacramento, CA USA
    Brand I have on now is Standard (O2 and plug wires). I have used their stuff before, and have no complaints at all. Always seems to be very good. Plugs I am using NGK. /forums/images/graemlins/smile.gif
