PLUGS AND WIRES?
Discussion in 'The Garage' started by CHEVY 4WD, Mar 19, 2003.
  1. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    Whats everyons favorite plugs and wires?(for a HEI)
    I was looken at some MSD 8.5MM wires But have no clue about pulgs
  2. Don
    Don 1/2 ton status
    May 30, 2002
    1,778
    Spokane Washington
    A.C. or Autolites. Never never a Champion! /forums/images/graemlins/shocked.gif
  3. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    MSD wires are great wires. Those 8.5MM wires are the same wires top fuel guys run (but they add alot more protection on top because of the mag setup). As for plugs, either autolite, or AC Delco.
    Dan /forums/images/graemlins/burb.gif
  4. bowtiepower00
    bowtiepower00 1/2 ton status
    May 11, 2000
    924
    AZ
    MSD and Delco, no contest. I've ran em both in several vehicles and have no complaints.
  5. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    MSD 8.5's and Champion Truck Plugs. That is what I have run in my truck for the past 3 years. I really like both of them.
  6. MJB774X
    MJB774X 1/2 ton status
    Sep 26, 2002
    574
    SO CAL
    8.5 wires, you got a race motor ah, just like hondas with those 8.5 wires, wire diameter is bigger then the fricken spark plug, waste of money, it's all a gimmick, unless you got a serious coil or magneto, stock wires will do just fine, buy some lifetime guarentee from autozone and your good to go
  7. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    Well I run MSD cap, rotor, dust cover for HEI, remote Blaster SS coil, and MSD 6 Offroad box, so the wires are something that does help me.
    Even if you are going to run a stock ignition beside the wires, it is worth it to get MSD 8.5's. It gets you the most power to the spark plug and maximizes efficiency of the system which is a good thing. I first switched to the Borg Warner Nascar Select wires on my truck after I ditched the stock wires. I did notice a little difference. Then when I went to the MSD 8.5 super conductors I notice an improvement in the igntion again, so I would say go with the best the first time, maximize the ignition output and then if you decide to step up the rest of the ignition you don't have to buy new wires again.
  8. hardcore71
    hardcore71 Registered Member
    Nov 21, 2002
    86
    Weare NH
    nothing but a.c.'s for me. I just got a set of accell supper stock "spiral core's" much better than crappy carbon core wires but still reasonably priced.
  9. Chris_T
    Chris_T 1/2 ton status
    Mar 17, 2001
    718
    Saskatoon, SK
    I run AC Delco plugs and Taylor Spiral-Pro 8mm wires. I noticed a difference on the upgrade and I love the plug boots on the wires
  10. rick88blaze
    rick88blaze 1/2 ton status
    Jan 24, 2003
    2,342
    Knob Noster, Mo.
    on the plugs, i run the bosch +4's they are about $6 a plug. i noticed a gain in power and a small gain in mpg.
  11. CHEVY 4WD
    May 14, 2002
    1,773
    Florida
  12. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    This is the part number I used, but I have an 85. They fit my truck pretty well.
    121-3141-9
  13. BigRed89
    BigRed89 1/2 ton status
    Oct 28, 2002
    223
    Los Angeles, CA
    MSD 8.5mm wires and Accel header plugs. Prior to my headers, I used AC Delco plugs.
