plugs for carb vac ports...where can I find some?
Discussion in 'The Garage' started by 77Jimmy, Jul 17, 2003.
  1. 77Jimmy
    77Jimmy 1/2 ton status
    Sep 3, 2002
    661
    Atlanta, GA
    I need to plug some vac holes in my carb. Anyone know where I can get some little rubber caps or something similar?
  2. 88Silverado
    88Silverado 1/2 ton status
    Mar 13, 2003
    2,664
    Quartz Hill, So. Cal
    Most any autoparts store.
    I get mine at the local Autozone. They come in a variety pack.
  3. 77Jimmy
    Sep 3, 2002
    661
    Atlanta, GA
    Ok, thanks! /forums/images/graemlins/thumb.gif
  4. dyeager535
    26,979
    My personal favorite is to go get some set screws, and pull the fitting out, tap the hole, and use the set screws to plug it. I've seen the stupid rubber caps blow off in a backfire, and they aren't well suited to engine heat...they start to crack pretty shortly after being installed.
  5. mastercraftkpk
    mastercraftkpk 1/2 ton status
    Mar 12, 2003
    192
    Houston, TX
  6. COCHEV
    COCHEV 1/2 ton status
    Jul 9, 2002
    4,055
    Washougal WA
    What ever happened to just using a small section of vac. line and a little bolt or screw /forums/images/graemlins/thumb.gif /forums/images/graemlins/tongue.gif
  7. chulisohombre
    chulisohombre 1/2 ton status
    Apr 11, 2002
    4,140
    14
    Bangor,Pa
    i didnt know where to find the little caps. so i used some vaccuum line and squeezed some silicone rtv in the end and left it like that with no problems.
  8. 75-K5
    75-K5 3/4 ton status
    Apr 28, 2002
    5,353
    Anderson, Indiana
    That's what I do. /forums/images/graemlins/grin.gif
