plumbers tape on hydro assist??
Discussion in 'The Garage' started by oneofthefewbmx, Mar 24, 2007.
  1. oneofthefewbmx
    oneofthefewbmx 1/2 ton status
    Oct 6, 2004
    579
    Copperas Cove, TX
    hey guys, im putting in my hydraulic assist today and i was wondering, before i start, do i need to put some kind of sealant on the fittings on the lines? like plumbers tape on the threads? i was goin to do it anyway but i dont know if that would hurt it becase ive never heard of, say, doing that to your power steering lines ya know....thanks guys....
  2. ryan22re
    ryan22re 1/2 ton status
    Feb 5, 2005
    3,368
    Irmo, SC
    PS lines do not need teflon tape.
    NPT (pipe fittings) do. I.E. the hydro assist fittings.
    Your PS lines should either be a flare or have an o-ring fitting.
  3. oneofthefewbmx
    Oct 6, 2004
    579
    Copperas Cove, TX
    sweet...that is what i thought....thanks for the quick reply!
  4. dremu
    Feb 27, 2000
    15,963
    454
    East of San Francisco
    God there and I thought you meant you were gonna mount your ram to the axle with the metal plumber's tape :haha:
    -- A
  5. runamok151
    runamok151 1 ton status Premium Member
    Oct 24, 2005
    12,557
    1,482
    the armpit of the east coast, 08046
    isn't that what duct tape is for?:rolleyes:
  6. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    I used the liquid thread sealant from Loc-tite on my fittings.
    The NPT fittings only the -6 fittings are self sealing:D
    Ira
  7. oneofthefewbmx
    Oct 6, 2004
    579
    Copperas Cove, TX
    i see...that is exactly what i did...teflon taped all the fittings except except the 6 because they had o-rings...thanks guys....ah, one more question, was is easiest to center the ram by turning the wheels all the way to one side with the ram all the way to that side and just welding it there or what? how did you guys find out where to weld it to the tie-rod? thanks
  8. mikey_d05
    mikey_d05 1 ton status GMOTM Winner
    Nov 23, 2004
    10,453
    Minnesota
    Put it on stands, cranked it back and forth, left it at full lock when I tacked it, cycled it again to make sure it would go the whole distance, welded.
  9. sandawgk5
    Oct 28, 2003
    6,881
    I went full lock, pushed the ram all the way in and marked where the tabs met the tie rod, moved full lock the other way and pulled the ram out and marked the tabs again. I did some calculations and stuck the tabs. I have not had any problems and I run a stock tie rod (only because I am cheap):D
    Ira
  10. oneofthefewbmx
    Oct 6, 2004
    579
    Copperas Cove, TX
    sounds good to me....thanks guys :bow:
