Plywood or Particleboard?
Discussion in 'Audio' started by Derf00, Dec 3, 2000.
  1. Derf00
    Derf00 1/2 ton status
    Jul 25, 2000
    1,683
    Abilene, TX
    I have removed the rear side panels and plan on building new ones, covering with carpet, and installing 6x9's and 10" sub. Other than price, is there any difference between plywood or particleboard?
  2. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    IMHO the particleboard will make it sound better just put a sealant on it to keep the moister off it
    s.smith 77blazer lookin 4 mud
  3. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    Agreed..........I used particle board, it is easier to work with too, as you will probably have to use a router to modify the area back by the latches to fit right.......especially if you are putting 10" subs in the board, which means you will probably need decent thickness board. Used 5.8" myself. Pics on my site.........
    <font color=black>'79 - 406 TPI -<font color=orange> K5#5 - <font color=blue>See it at---&gt;http://www.blazzinor.coloradok5.com
  4. KingSmoth
    KingSmoth Registered Member
    Jul 5, 2000
    55
    Use MDF, best thing to use for sub boxes. It is denser than the other two.
  5. '73 K5
    '73 K5 1/2 ton status
    1,763
    Kansas
    I install stereos 40 hours a week, and the only thing I use is MDF, medium density fiberboard. Its stronger and way more water resistant than regular old particle board and its about the same price.
    '73 K5
    Chevy good...Ford bad
  6. Blazer79
    Blazer79 1/2 ton status
    1,816
    Guatemala, Central America
    I'm in the middle of building a pair of boxes for my subs. I'm using 3/4" MDF. I didn't even know it existed before checking this forum. It's a great material. Even easier than particle board for working, but much better.
    <font color=blue>//////
    http://blazer79.coloradok5.com
    </font color=blue>[​IMG]
  7. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    Which one would be better suited towards bolting my Hi-Lift jack and 4-Way etc to. I am going to coat the entire thing in Herculiner to seal it.
  8. Derf00
    Jul 25, 2000
    1,683
    Abilene, TX
    Follow up:
    I purchased 3/4" MDF. It is damn heavy and a very good material. I wouldn't hesitate to bolt a jack or anythingelse to it. I plan on sealing it prior to the carpet and speaker installation.
