Pneumatic cylinder search help
Discussion in 'The Garage' started by CyberSniper, Jan 18, 2004.
  1. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    OK, I'm looking for something specific. My Senior Design team seems to think we have to buy a high-dollar actuator (fancy-pants engineering term) to do this but I don't think we do.
    Here is what I need:
    1. Dual-action pneumatic cylinder with a 6" stroke capable of moving 10lbs or less (probably around 4lbs, no side load)
    2. It has to operate at no less than 50"/second
    3. Ideally, it'd do a full cycle (up and down) in 230ms or less. One direction can be as slow as 170ms but the other direction needs to make up for it
    I have 250psi@5cfm right now but I can get whatever is necessary. Hydraulics is an option but since we're moving a small load we don't deem it necessary.
    Do you guys have any suggestions on where to look?
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    what ya makin? /forums/images/graemlins/thinking.gif
    check mcmaster-carr ive seen some pneumatic cyclindres in the catalog
    here is their web site
    www.mcmaster.com
  3. Stomper
    Stomper ΜΟΛΩΝ ΛΑΒΕ GMOTM Winner
    May 11, 2002
    3,767
    Iowa
    Ebay......I've gotten many cylinders there. Most were new, for cheap. Ask the seller for the part number and look it up to see if it will work for ya.
  4. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    im sure you can get an electic actuator for the same properties. 4lbs is light for most actuators. with electrig you would save weight on the total of your project. or im assuming anyway, since it would most likely have a battery already.
    Grant
  5. GMCLegacy
    GMCLegacy 1/2 ton status
    Jan 24, 2002
    620
    Grand Haven, MI
    bimba http://www.bimba.com has a decent selection of cylinders that are pretty resonable. used a lot of them at work, just keep them away from heat.
  6. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    heres one i found on grainger that might work for ya Click Here
