Point system to HEI
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by scavenger, Sep 21, 2000.
  1. scavenger
    scavenger 1/2 ton status
    Mar 31, 2000
    111
    Southern Wisconsin
    Just wondering if anyone knows if I can use a small block HEI distributor to replace a big block point system distributor. I am planning to do this swap to a 366 or 400 (not sure which motor it is) out of a Chevy C50 truck. If this is possible I would also need to know the specifics involved in making the swap......thanks
  2. k5king
    k5king 1/2 ton status
    Jul 23, 2000
    571
    Parkesburg, Pennsylvania
    i believe that all chevy distributors are the same no matter if it's a big or small block. you will however need to change the wiring. you can either cheat and just run a hot wire to the dist. or get the proper wiring harness
    DRIVE IT LIKE YOU STOLE IT
  3. JAXSTER
    JAXSTER 1/2 ton status
    Mar 15, 2000
    181
    DFW, TEXAS
    the only difference is the vac advance. been there done that.
  4. I know that a big block and a small block use the same one,
    but I dont know if the tall deck big block motors use the same one or not.
    Good luck.
    IF IT AINT BIG IT AINT BAD!!!!!!
  5. scavenger
    Mar 31, 2000
    111
    Southern Wisconsin
    Thanks for the info. I guess the motor is actually a 350 so I shouldn't have any problems. I just assumed that all C50 trucks in 1969 had a big block of some sort, and the 350 was not an option.......thanks
