Points to HEI?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by TX Mudder, Nov 20, 2000.
  1. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    I'm putting an HEI engine where a points engine once was. I think I heard about a resistor somewhere that need to be bypassed or something like that. Anyone know what I'm talking about?
    Anything else I need to do with this conversion?
    -- Mike
  2. edeslaur
    edeslaur Registered Member
    Oct 31, 2000
    69
    Portland, Oregon
    Check your voltage at your coil side. If it's 12V or more, just plug 'er in. Otherwise you have to hunt down the resistor. You'll see around 6v if you have the resistor.
    The last one I converted was a 68 el Camino, sorry no info on Blazer.
    Eric D
    88 K30
  3. Scoobydoo
    Scoobydoo 1/2 ton status
    Jun 9, 2000
    244
    Phoenix / Peoria ARIZONA. (75thAve/DeerValley)
    Do NOT use the factory "HOT" or "+" wire at all.
    Just run a new wire from a 12V off your fuse box, be sure it is one that only comes on with the key. Some years even have an extra spot on the fuse box that says "Ignition", use that one.
    Scooby Dooby Doo !!!
  4. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    When I was going from Points to MSD I too had to eleminate the resistor. On mine it was a ceramic stick about 2 inches long located on the fire wall in the engine bay. The MSD conversion was very simple and made night and day difference. Good luck
    http://www.burt4x4.coloradok5.com
  5. Gopherkiller
    Gopherkiller 1/2 ton status
    Aug 14, 2000
    188
    Don't forget to put the different sparkplugs with HEI.
