points to HEI
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by grunt11b40x, Oct 12, 2003.
  1. grunt11b40x
    grunt11b40x 1/2 ton status
    Mar 1, 2003
    124
    winston salem, nc
    I want to swap in a HEI distro, does anyone have some how to info that they would share? /forums/images/graemlins/thumb.gif
  2. big pappa b
    big pappa b 3/4 ton status
    Jan 3, 2003
    6,328
    Falcon, Colorado
  3. xnoahx
    xnoahx 1/2 ton status
    Oct 12, 2000
    817
    Ventura, CA 93004
    I did it on my 73 and it made the biggest difference, starts up much easier now than it used to and runs better. if you have any questions send me a pm and ill do my best to answer them. one of the best mods on my truck
  4. roadhawg
    roadhawg 1/2 ton status
    Aug 15, 2003
    495
    Oregon
    Make sure the hot wire going from your ignition to your distributor is not a resistor wire, it it is change it out, you need a full 12 volts for HEI. a points distributor setup will have a resistor on it somewhere to keep from burning up the contacts prematurely.
  5. Panther
    Panther 1/2 ton status
    Aug 31, 2000
    845
    South Jersey
    It is a very easy swap and well worth it. To avoid any wiring issues, I ran a new piece of wire from the cap to the fuse box.
    My only issue was that the first one I dropped in had a bad module and then I dropped in the dist 180* off the first time. There are a lot of threads on setting your timing/swapping in a new dist. Try these two for starters:
    http://coloradok5.com/forums/showflat.php?Cat=&Board=garage&Number=794579
    http://coloradok5.com/forums/showflat.php?Cat=&Board=blazer4x4&Number=787611
    (the latter was my thread when I did my head rebuild and my dist was off when I put everything back together)
    HTH /forums/images/graemlins/laugh.gif
