polishing help!!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Confederate9, Aug 31, 2001.
  1. Confederate9
    Confederate9 1/2 ton status
    May 29, 2000
    1,686
    Greensboro NC
    ok i need some help
    i jsut got my new wheels. they are american racing and their polished alumenum. and there is black stuff all over it, and i got some of it off, but whats the best way?
    <a target="_blank" href=http://confederate9.coloradok5.com/>confederate9.coloradok5.com/</a>
    <font color=red>K5: Because size DOES matter</font color=red>
  2. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    First thing to try is some brakedust remover, like Eagle One. After that, get a can of Mother's Mag and Aluminum polish, and put a little elbow grease in it.
    1 tequila 2 tequila 3 tequila Floor
    <a target="_blank" href=http://pugsley.alloffroad.com>pugsley.alloffroad.com</a>
  3. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Uh, if they're black from corrosion, then it takes a LOT of elbow grease. [​IMG] I'm using the drill and some Dico brand buffing wheels that I got in the tool crib at Home Depot. They also sell an adapter to use then on your drill. And plenty of Mothers Mag and Aluminum polish. [​IMG]
    If they're just black from brake dust, then wheel cleaner and a platic bristle brush will clean them up pretty well.
  4. Rob 85K5
    Rob 85K5 1/2 ton status GMOTM Winner
    1,487
    Pensacola, Florida
    If is really bad, you can use 000 or 0000 steel wool to clean them and then polish &amp; buff them with Mothers after.
    I did this to my polished Welds all the time, it works to get tar and asphalt off.
    Rob 85K5
    <font color=orange>Bleedin' Chevy Orange</font color=orange>
  5. 90blzr
    90blzr 1/2 ton status
    Mar 25, 2001
    3,027
    SO CAL
    If its just brake dust, use some Simple Green, it works great! A couple friens of mine use it on there wheels and they are $$$ (Billet Specialties, Colorado Customs, etc). I like to use Dr. Goose's Magic Mix Polish on my Welds. Its the best polish I've found! Good luck!
  6. newyorkin
    newyorkin 1 ton status
    May 8, 2001
    16,555
    157
    Los Estados Unitos
    I found out a couple weeks ago this stuff from wallmart called "revive a drive" works incredible on unpainted metals (in the oil drain pan/funnel section). It's driveway stain remover, but the label also says "when using on equipment...", so I figured what the heck. I let it soak into the fronts for a couple minutes and rubbed 'em lightly with a kitchen scrubbing pad, and they sparkle now!! I have aluminum wheels, they were covered in brake dust. I don't know how the stuff would do on corrosion, though. It worked really well cleaning up my stainless tailpipe, wheelwells (ancient caked mud), and grease stains on the chassis, too.
    Ratch
    <a target="_blank" href=http://k5.8m.com>k5.8m.com</a>
    **Ever stop to think... Then forget to start again?**
