POLL - B&M vs. Hayden - Tranny coolers
Discussion in 'The Garage' started by KRAZIE87K5, Nov 13, 2003.
  1. KRAZIE87K5
    KRAZIE87K5 1/2 ton status
    Feb 23, 2001
    3,369
    Chicago, IL
    Hey all,
    Just a quick poll to check on tranny cooler preference:
    Which one would you buy? Are there really any others that are any good?
    Thanks again!
    -Dan
  2. 83ZZ502_Jimmy
    83ZZ502_Jimmy 1/2 ton status
    Feb 7, 2001
    3,103
    Richmond, VA
  3. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    summit has a 26,000# stacked plate B&M also.... that one gets my vote...
    j
  4. Mudzer
    Mudzer 1/2 ton status Author
    3,639
    Missouri
    B&M PN 70266
    By far the best IMHO.
    Its real big and works well.
    Click Here for a description
    John
    Dan, thats the one like you sold me! It works good. My tranny temp is about 180 when it has fluid! /forums/images/graemlins/thumb.gif
  5. Lance
    Lance 1/2 ton status
    Mar 4, 2002
    606
    Birmingham, Alabama
    I voted B&M PN 70266, like 83zz502Jimmy did. That's what I run in front of my "built" 700r4 and I do not have tranny cooling issues. Although there are some instances, like on a trail in the middle of one of Alabama's 100/100 summers, where I think having an external electric fan would be beneficial.
    BTW, I run my fluid through the radiator's heat exchanger and then on to the cooler. That way I don't have any issues with "overcooling" my ATF in the winter either.
  6. laketex
    laketex 3/4 ton status
    6,220
    North Texas
    I dunno... /forums/images/graemlins/confused.gif...my 465 dont require one.
  7. 83ZZ502_Jimmy
    Feb 7, 2001
    3,103
    Richmond, VA
    I actually voted other.. /forums/images/graemlins/grin.gif The one he listed was 70264
    Then 70266 is the bigger of the two.
    John
  8. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    In the Burbs close to Tulsa, OK
    B&M number 70266
    I have this one. It has the fittings instead of barbs. I used 5/16" steel brake line to hard plumb it in. I have no rubber hoses that will blow out.
    BTW, this is the exact same cooler as the factory oil cooler on my K5...
  9. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    Normally I like TCI products over B&M. But I do like this B&M tranny cooler . I like the idea of a fan on it. I think I'd go with part #130-70297. [​IMG]
  10. K5DRAGER
    K5DRAGER 1/2 ton status
    Jul 27, 2001
    1,164
    Momence, IL
    The B&M 70266 is the one I'm using for my full hydro cooler. And another will be installed when I install the th400 this winter. I just went to Menards, to the plumbing section and bought a 1/2 inch male to 3/8 barb fittings. /forums/images/graemlins/thumb.gif
  11. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    TH 400? Gave up on the 700/241 or what?
  12. Judd
    Judd 1/2 ton status
    Sep 27, 2002
    175
    N.E. Ga
    Other! A unused AC condensor. /forums/images/graemlins/thumb.gif
  13. supersize75
    supersize75 1/2 ton status
    Sep 27, 2002
    2,638
    gilbert az......by Phoenix
    other...
    a huge stacked tranny cooler I found in the ford area at a junk yard....3 bucks, as for mounting it...I welded it on, no more radiater pin thingy's for me /forums/images/graemlins/thumb.gif
  14. K5DRAGER
    Jul 27, 2001
    1,164
    Momence, IL
    Yep going with a th400/203/205 over the winter.
  15. 77Jimmy
    77Jimmy 1/2 ton status
    Sep 3, 2002
    661
    Atlanta, GA
    Hayden has worked great for me...went from 200-210ish to 160-170ish. /forums/images/graemlins/thumb.gif
  16. tch777
    tch777 1/2 ton status
    Jan 15, 2003
    244
    Colorado Springs, CO
    I like the tru-cool coolers. They are stacked plate, low pressure drop and have a bypass for when the tranny fluid is too low. I have PN 4590 on my F350, but that is a huge cooler, I will get one of their smaller models for my SUB.
    Tim
