Poll: Choose my next shocks
Discussion in 'The Garage' started by Jonny-K5, Oct 12, 2005.
My next set of shocks should be...
  1. Bilstien standard
    2 vote(s)
    4.5%
  2. Bilstien 5100 series
    22 vote(s)
    50.0%
  3. Pro Comp MX6
    5 vote(s)
    11.4%
  4. Fox 2.0 remote res.
    10 vote(s)
    22.7%
  5. Sway Away Racerunner 2.0 remote
    5 vote(s)
    11.4%
  1. Jonny-K5
    Jonny-K5 1/2 ton status
    May 27, 2003
    1,654
    SoCal
    I want to upgrade my shocks from the current rancho 9000x's to an entry level gas charged monotube style. i will just be doing the front for now. plans for the truck are to be able to go from the trail to the desert and still be functional. also thinking about ditching the front swaybar if the shocks are stiff enough. no way i can drive without it on the rancho's w/ 3" EZ rides.
    whatever shocks i choose will be 10-12" travel and using custom mounts.
    leaning towards the bilstien 5100 but thought i'd throw in the others for good measure. ideally i'd like to spend under 150 each, but i'd go up to 200 each if its worth it. not sure how much the fox or racerunners are, but i think the cheaper ones can be had for around 200.
    also looking for good(cheap) places to buy these shocks. so whatever you choose please post up a good vender for them if you could. thanks
  2. muddyblzr
    muddyblzr 1/2 ton status
    Nov 2, 2004
    623
    houston/san antonio texas
    they ones id suggest arent listed there on PIG www.polyperformance.com the bbcs shocks are 15'' travel but they make a smaller set called lwcs i think they are 10-13'' travel
  3. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    ive heard nothing but good things about bilstein 5100s. pretty reasonably priced too
  4. big94gmc
    big94gmc 1/2 ton status
    Sep 1, 2004
    3,651
    No VA.
    I have the Sway-away's on the front of my truck.... MORE flex then I need, so, I guess, no problems from them. :D
  5. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    Any of the above EXCEPT the Pro-Comps and the Bils stds if it's for a street driven truck.
  6. blazerpro79
    blazerpro79 1/2 ton status
    Jan 4, 2005
    528
    Simi Valley, CA
    id say check out the bilstein 5150s. those are some mean little guys. same as the 5150 but with a piggyback resevoir. not so many people run them, but ive heard good things. i would either get those, or if your willing to spend a little more, try the 7100 remote resevoir bilsteins. they rum usually around $180 or so a peice, but they are worth it, completly rebuildable and have t6 bodys.
  7. blazerpro79
    Jan 4, 2005
    528
    Simi Valley, CA
    oh and by the way, the bilstein 5100 is the bilstein standard.
  8. Jonny-K5
    May 27, 2003
    1,654
    SoCal
    really? i must have read there product page wrong. i didnt know the 7100 series are under 200. that might be the sweet setup.
  9. Diesel Dan
    Diesel Dan 1/2 ton status
    Feb 27, 2002
    798
    Warren, Ohio
    Currently I have Bilstein 7100s(10") on the front and 5150s on the rear. Price was $170ea for the 7100s and $99ea for the 5150s. That said I think I should have went with the 7100s on the rear also.
    Pros for the 5150s are rubber eye bushings and painted body for all weather protection.
    Cons for the 7100s are the uncoated body and possibly the unsealed rod ends for winter driving, will have to see how this plays out this winter. I did coat the 7100s with a couple coats of clear, time will tell.
    BTW, truck is a '98 Dodge/cummins and the 7100s have the 5th out of 6 heaviest valving and does an excellent job controlling the heavy truck on the dunes and high speed wash board.
  10. Jonny-K5
    May 27, 2003
    1,654
    SoCal
    did you change the valving yourself or order it that way? how easy is it to change the valving? do your 7100's have remote reserviors? where did u buy them from?
  11. jekbrown
    May 19, 2001
    45,030
    362
    Vancouver, WA, USA
    +1
    BBCS is the shizzel.
    j
  12. Diesel Dan
    Feb 27, 2002
    798
    Warren, Ohio
    The part number, IIRC, was AK7110-R06 with 360/80 valving. They were ordered with the heavier valving. Bought them out of Detroit, E-shocks? maybe. The site is under Bilsteins main page. Customer service was lacking but price was good and somewhat local for me.
    Yes, they have remote resevoirs.
