Poll: Detroit or Lockright locker?
Discussion in 'The Garage' started by RockinChevy, Feb 11, 2007.
  1. RockinChevy
    RockinChevy 1/2 ton status GMOTM Winner
    May 9, 2005
    2,313
    Chandler, AZ
    Guys, bear with me and school me on differences between the two lockers.
    Sorry if this was covered before but this is for the front 10bolt. I've decided to hold off the Dana60 and keep what I already have. I have a 14BFF also and that will have a Detroit indefinitely, but to keep this thread on point, this is for the 10bolt.
    I want a strong but street-friendly locker that won't break. I did a search on price comparison, Detroits are roughly $600 and Lockrights are $260.
    One other question, is there a closed carrier type for these lockers?
    My truck is currently in the crossover install. In the upcoming months, I will be going hydro-assist, and install chromoly axles and CTM ujoints.
    Anybody have some good and bad points with either locker, post up.
    I don't intend to lead into a heated debate but I need help in making a decision.
    Thanks, fellas
    EDIT: forgot to mention I will be using 5.13 gears with 37" tires
  2. k204dr
    k204dr 1/2 ton status
    Aug 27, 2004
    463
    TN
    The lockright will be the better one for that axle. works good for the price, and you won't feel so bad when you have to junk the front after you bust it. :D
    Save the extra money for a d60.
  3. RockinChevy
    May 9, 2005
    2,313
    Chandler, AZ
    :thinking: I'm listening....
  4. roadnotca
    roadnotca 3/4 ton status
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    LockRight, but if the gearing or tires are too tall, it won't make a difference.
  5. RockinChevy
    May 9, 2005
    2,313
    Chandler, AZ
    I'd love to go ARB if I had the $$$$ for it ha ha
    Also I edited the first post that I will be using 5.13 gears with 37" tires... Will this affect my locker choice?
  6. garlicbreath
    garlicbreath 1/2 ton status
    May 17, 2003
    1,136
    Denver
    Why 5.13's with 37's?
    Are you really going to spend the money on chromoly axles and ctm's for a ten bolt?
    It depends on how you wheel, get the lockright and save up.
  7. roadnotca
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    ARB = Axle Really Broke
  8. RockinChevy
    May 9, 2005
    2,313
    Chandler, AZ
    Well, the consensus of people I talk to locally have pressured me into not getting a D60 for cost reasons.
    I chose 5.13s because I want the low gearing and knowing I won't have to regear lower in the future. As for 37s, I chose this as the maximum size tire I will go with the 10bolt. This being said, I can have the speedometer adjusted for the final time and move on to other projects.
  9. RockinChevy
    May 9, 2005
    2,313
    Chandler, AZ
    :confused: I hear 5.13s and 37s are okay for 10bolts.
  10. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    detroit for $600? yikes. i paid $379 for 14b detroit and $450 for d60 detroit. might wana search around for some better prices. for a 10b tho id go with a lockrite
  11. RockinChevy
    May 9, 2005
    2,313
    Chandler, AZ
    Yup, $600 detroit for 10bolt.. that's the cheapest I could find through google. I said the same thing :yikes:
  12. roadnotca
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    :D When its unlocked.
  13. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    if i can find it cheap, can i get a prize?:D
  14. RockinChevy
    May 9, 2005
    2,313
    Chandler, AZ
  15. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    i found it $50 cheaper;)
  16. RockinChevy
    May 9, 2005
    2,313
    Chandler, AZ
    Still up on the fence thinking about it... I'm leaning towards the Lockright.... I'll let this go on for a day and see what everybody else says about the locker choices
  17. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    get a lockright. detroit is too hard for the 10b to handle. alot of ppl run lockrights w/o problems.
  18. W7NB
    W7NB 1/2 ton status
    Nov 9, 2006
    716
    Springtucky, OR
    Go with the lockright...
    For now anyway. I have lockrights on both ends in 10 bolt/3.73/33 combo and have not broken anything YET, but I mainly rail ride and play in a little mud.
    ANYTHING beats an open diff, and he lockrights keep me moving as well as the blazer would go with anything else.
    TO be quite honest, I think 35's are the limit for 10 bolts. There is just too much weight out there for the front yokes and gear to handle when you get any bigger. perhaps 4:42 or 4:55 (I'm not sure the next ratio above the 4:11's) is a better choice. Lower chance of breakage and you can sell them to a noob when you go to the 1 tons.
  19. RockinChevy
    May 9, 2005
    2,313
    Chandler, AZ
    Alright... made up my mind. Lockright for the 10bolt and Detroit for the 14B.
    Thank you everyone for the input :waytogo:
  20. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    now how much did you find the 14b detroit for?;) :D
