POLL: Fuel Pump type
Discussion in 'The Garage' started by big pappa b, Aug 16, 2004.
  1. big pappa b
    big pappa b 3/4 ton status
    Jan 3, 2003
    6,328
    Falcon, Colorado
    What are you running...mechanical or electric?
  2. jakeslim
    jakeslim 1/2 ton status
    Sep 18, 2002
    2,686
    Napa, CA
    ....mechanical... /forums/images/graemlins/whistling.gif
  3. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    I run an electric but only because I have to. TPI needs 45 psi roughly to run and a mech pump can't do that.
    On my carb I ran a mech pump.
    Harley
  4. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    I prefer electric vane type. Don't need a pressure regulator or a return line. And if one goes bad swap a one in its place. It'll never wear the lobe off the cam, won't fill your block with gasoline, and if you run it out of gas you won't have to ruin your starter to get fuel back in the float bowl.
  5. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    I like the electrics. Lots of different reasons I guess but don't get a holley. Just a leaking mess. I have a Carter on my DD and I'm loving it. Very quiet compared to the holley. One nice part about an electric is if somebody runs out of fuel on the trail you can help them out buy pumping a little gas into their tank. Course, fuel on the trail is more expensive than at the pumps. /forums/images/graemlins/thumb.gif
  6. diesel4me
    Jul 24, 2003
    17,537
    921
    Massachussetts
    My 82 diesel has both the stock mechanical lift pump and an electric fuel pump near the tank the previous owner installed,probably to help bleed the fuel lines of air when the fuel filters are changed--it seems to run better if I leave the electric one on. /forums/images/graemlins/crazy.gif
