POLL gloss or flat?
Discussion in 'The Garage' started by BranndonC, Jul 22, 2003.
  1. BranndonC
    BranndonC 3/4 ton status
    Mar 18, 2002
    8,591
    Anaheim, Ca
    here's my delema. I've begun to paint the underside of my truck black with this semi-gloss rustoliuem can i had, well it looked great but i ran out, so i ran to sears to pick up some more, but they were out of that type, so i bought black rustolium that was high heat formula (1200 degree) so i bough 5 cans thinking i could use this on everything. but now it looks too muted and like a dark grey, so i need opinions. Which color do you like better
    Its not really this light gray, just the flash did it, it's pretty dark but still looks gray
    <FORM METHOD=POST ACTION="http://coloradok5.com/forums/dopoll.php"><INPUT TYPE=HIDDEN NAME="pollname" VALUE="1058930174BranndonC">
    Gloss or Flat
    <input type="radio" name="option" value="1" />Semi-Gloss
    <input type="radio" name="option" value="2" />Flat
    <INPUT TYPE=Submit NAME=Submit VALUE="Submit vote" class="buttons"></form>
  2. daleearnhardt01
    daleearnhardt01 1/2 ton status
    Aug 29, 2002
    3,223
    Richmond, VA
    I just did the underside of mine with Rustolem Gloss Black. It looks awesome. I used like 8 cans...I think, but definetely use gloss. /forums/images/graemlins/thumb.gif
  3. BranndonC
    Mar 18, 2002
    8,591
    Anaheim, Ca
    pics? i'd like to get an idea of how it'll come out /forums/images/graemlins/thumb.gif /forums/images/graemlins/k5.gif
  4. daleearnhardt01
    Aug 29, 2002
    3,223
    Richmond, VA
    Let me see if I took some, if not ill get em in the morning.
  5. daleearnhardt01
    Aug 29, 2002
    3,223
    Richmond, VA
  6. 88Silverado
    88Silverado 1/2 ton status
    Mar 13, 2003
    2,664
    Quartz Hill, So. Cal
    Actually I like the Rustoleum Epoxy Satin Black.
    Takes about a day to dry, not as flat as flat or as glossy as gloss. Nice sheen and lasts a long time. /forums/images/graemlins/thumb.gif
  7. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    gloss, dirt/mud will release from a smooth surface! /forums/images/graemlins/deal.gif
    Flat or semi will always look dirty
  8. BiggerIsBetter
    BiggerIsBetter Registered Member
    Aug 9, 2002
    23
    Livermore, CA
    I've used both semi and flat before. Semi looks so much better.
  9. FL84K5
    FL84K5 1/2 ton status
    Aug 19, 2001
    936
    Sarasota, FL
    What kind of prep work is needed to paint the undercarriage?
  10. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    I take a degreeser (like for wheels) and spray all around and I have a RV brush (for washing aluminum) and scrub the underside then rinse it off. After its dry I take one of the wire brushes that has the paint scraper on the end (the type youuse for painting houses) and I crawl under with safty glasses on and go to town! Take an air hose out and blow off the dust and chips then I pull up on a hill/ditch out back in the grass with about 4 cans of paint and 3 cans of truck bedliner spray on stuff. Use the bedliner on the floors, inner wheel wells and rockers and the paint on the axles, frame, tank and lightly spray the springs.
    I used the hammerite rust cap paint on my frame and axles, its a metallic black. paint can
    pic one
    pic two
    pic of the wheel well after bedliner spray
    before
    after
  11. marv_springer
    marv_springer 1/2 ton status
    Aug 3, 2001
    2,781
    Mesa, Arizona
    gloss or flat?
    Uhhh... err.... floss!
    ... I hate answering ?'s under pressure like that! /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
    Marv
  12. TruckNutzDude
    TruckNutzDude 1/2 ton status
    Mar 31, 2003
    3,532
    Agawam, MA
    Are those pics of my truck??? /forums/images/graemlins/eek.gif /forums/images/graemlins/eek.gif
    I say go with Semi-gloss. It looks much better for much longer, gloss is just to um... glossy. It makes all the rust look worse because it reflects so much light, and when it's dirty, it's really dirty! Anyways, just my $.02 /forums/images/graemlins/grin.gif
  13. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    GLOSS... I work at a faimly owned hardware store and we sell BLP Paints, They have a spray paint(also in pints quart, &amp; gallon) called RUST-KILL and it work REALLY good. I dont know where else you could find it but I really like it.
  14. MTBLAZER89
    MTBLAZER89 3/4 ton status GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    I used this stuff I got at Wal Mart "Engine Enamel" (900*) with Ceramic in it. Low-gloss black. I use the Furd Dark blue and Daytona yellow too. seems to be pretty tuff paint.
