POLL Ignition Module or Fuel Pump??
Discussion in 'The Garage' started by k5freak44, Mar 23, 2006.
Fuel Pump or Ignition Module needs replacing?
  1. Ignition Module
    3 vote(s)
    75.0%
  2. Fuel Pump
    1 vote(s)
    25.0%
  1. k5freak44
    k5freak44 1/2 ton status
    Jun 1, 2004
    2,164
    Plano, TX
    I think im close, after replacing the fuel filter, EGR. Idle Control Sensor, and Throttle Body rebuild, i have decided i either need to replace my fuel pump or ignition module. I also checked the timing and its fine. Still havent checked for codes tho.
    Ive got a 91 TBI 5.7 and the idle on it is in and out like its trying to die. When i accelerate is is very slow and seems to try and die while accelerating. Takes like a block to get up to 30 mph. :(
    What do you think???
  2. 88Silverado
    88Silverado 1/2 ton status
    Mar 13, 2003
    2,664
    Quartz Hill, So. Cal
    CHeck the fuel pressure at the TBI. That should give you a clue if the pump is going bad or the sock on the pump is plugged. I had a similar problem when my fuel filter got plugged but you already changed that.
    Its also pretty easy to check if you have a good spark. Just have one of your friends put his pinky inside a disconnected plug wire while you start it.
  3. k5freak44
    Jun 1, 2004
    2,164
    Plano, TX
    i was told that because i have tbi that i cant do a standard oressure test on the fuel line
  4. opfor2
    opfor2 1/2 ton status
    Oct 28, 2002
    375
    Ventura County, CA
    Yes you can. You have to test the fuel pressure at the fuel filter on the passenger fuel filter. You'll need to use a TBI fuel pressure tester kit like the Actron III CP7817F. I bought mine on E-bay brand new and I paid 1/2 the price than retail.
    See http://www.actron.com/product_detail.php?pid=16175 for TBI fuel pressure tester kits.
  5. mike n
    mike n 1/2 ton status
    Oct 9, 2003
    101
    New York
    Plugged catalytic converter, maybe?
