POLL - Rear lift options - what are you running?
Discussion in 'The Garage' started by BurbinOR, Dec 16, 2002.
  1. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    Am totally /forums/images/graemlins/confused.gif about what I want to use in the rear of the Burb for lift...........rides excellent now on stock 3/4 ton springs, don't want to lose that. Flex is not an issue, ride quality is the priority with enough lift to fit 33's or 35's. Won't go shackle flip because of the potential towing issue.
    So please vote on what you have now -
    <FORM METHOD=POST ACTION="http://coloradok5.com/forums/dopoll.php"><INPUT TYPE=HIDDEN NAME="pollname" VALUE="1040089003BlazzinOR">
    What you're running in the rear?
    <input type="radio" name="option" value="1" />Lift Springs
    <input type="radio" name="option" value="2" />Blocks with stock springs
    <input type="radio" name="option" value="3" />Shackle Flip
    <INPUT TYPE=Submit NAME=Submit VALUE="Submit vote" class="buttons"></form>
    /forums/images/graemlins/burb.gif
  2. ben427
    ben427 1/2 ton status
    Mar 10, 2002
    1,123
    Waverley, Nova Scotia
    I have the ord shackle flip on my /forums/images/graemlins/truck.gif and im really happy with it. And ORD is commited to service too.
  3. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> If you're concerned with towing, how about getting some 6" springs and removing a leaf or two to bring it down to 4" of lift? Leave the overload for towing, should ride nice and soft but still work well for towing. Or put some air shocks in it and just pump em up when you're towing. </font color>
  4. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    i'm running the 6" Springer Suspension w/o a track bar. No way in hell i'd tow with it. I am not very expereinced in towing to begin with, but its really flexy so i don't have the stomach for it.
    I have heard that Marv tows a bit with his, and Dr. Watson came onto the PBB and said that the ORD flip could be towed with, might want to talk to him about that.
  5. 89GMCSuburban
    89GMCSuburban 1/2 ton status
    Nov 15, 2001
    3,005
    Thornton, CO
    Use blocks, but buy some traction bars if you really need them.
  6. mudhog
    Nov 6, 2000
    17,899
    portland oregon
  7. chevyfumes
    chevyfumes Court jester
    Feb 24, 2000
    38,584
    266
    Watch for the muzzleflash!
    I've got some blocks, I'll trade ya for summthin'.... /forums/images/graemlins/wink.gif
  8. GMCLegacy
    GMCLegacy 1/2 ton status
    Jan 24, 2002
    620
    Grand Haven, MI
    shackle flip and 4" blocks with stock leaf springs, it equates to a very soft flexy ride.
  9. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    www.springersuspensions.com
    or2play has it on his burban. i rode in it a few times. with no shocks it rides nice. im sure once he puts shocks on it it will ride LOTS better.
    be the second burban to run it man... i got it on my blazer, but have yet to try it out.
    Grant
  10. thatK30guy
    Jan 12, 2001
    32,076
    55
    Frank, I'm in the same boat as you are, deciding which springs to go with for my '89 Sub.
    I'm also planning around either 33's or 35's with the 35's on the higher priority list.
    Rear springs I'm thinking of 4" with zero-rates and also 4" on the front. Wanna have that rear up slightly higher in case of saggy butt.
    But if towing will sag it even more, I would go with 6" rear springs instead and still leave the 4" front springs there.
    I got this Sub mainly for towing. I still want to use it for a daily driver and for grocery-getting, too. /forums/images/graemlins/thumb.gif
    Rear blocks are out of the question. Too much axle wrap even when towing. I'm not planning to spend gobs of dough on this truck either, so traction bars are out, too.
    I can't use the stock springs on the truck now since one side is sagging about an inch or so lower than the other side. So either 4" or 6" springs are replacing them.
  11. COCHEV
    COCHEV 1/2 ton status
    Jul 9, 2002
    4,055
    Washougal WA
    my vote for you is lift springs as well. my buddy had 4" lift springs in rear of his 87 blazer and it rode great. won't have axle wrap issues of blocks or shackle flips. do the springs /forums/images/graemlins/burb.gif
  12. jekbrown
    May 19, 2001
    45,032
    369
    Vancouver, WA, USA
    stock springs, 1" ORD zero rates, 4" shack flip, revolvers, rockjunkies slightly taller than normal spring perches. When I put all that poop on, I took thesprings apart, degreased, put in new bushings, painted em all purdy, and slapped some UHMW-PE between each leaf to keep em from binding.
    j
  13. reddog64
    reddog64 1/2 ton status
    Nov 9, 2000
    3,325
    Federal Way, Washington
    I dontthink you can get axle wrap with a shackle flip, but I could be wrong... /forums/images/graemlins/confused.gif
  14. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    Go with the shackle flip. The shackle flip is only one (small) part in the problem with towing with a lift. If you keep the stock springs and don't flip the overload I don't think you will even notice the difference in ride. Suposidally the shackle flip imparts some digressive quality to the rate of the springs...but the overload adds in a huge progressive rate to the spring! Your 3/4 ton springs are stiff to begin with and it won't make that much of a difference if it does at all.
    The warning about towing that Stephan made was a bit more to cover his but. The problem that Grim had (that started the hole dabate) was a combination of meny different things (too soft of shocks, flipped overload, too much tung weight IIRC). IMO if you did the shackle flip and used some rs9000 shocks set to stiff when you tow you could not get a much better all around (including towing) setup.
    BTW: If you wanted to you could mount the flip bracket so that it would still be progressive. It all has to do with shackle angle....I'd have to look up which way you would want to angle it if you are intrested.
  15. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    I am running 5 1/2" SuperLift springpacks. Very smooth packs, i think I counted 8 leafs being used with teflon inserts. The Freeway ride is very nice and around town and even twisty roads my rig handels great. Oh and LifeTime warrenty too. I am very satisfied with them.
    Good Luck /forums/images/graemlins/thumb.gif
  16. or2play
    or2play 1/2 ton status
    Feb 22, 2002
    657
    Yuma, Arizona
    Well its safe to say I will not be towing with my suburban. Mabey with shocks and the track bar I'll change my mind. I know Marv said he has towed a few times with his blazer, but with as soft as the springer setup is (plus the extra weight of the suburban) I'm not planing on towing a thing.
  17. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    I have ORD 4" Shackle flip, and Tuff Country 3" springs, Total of 7" of lift for the rear, and 6.5" of lift up front. /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
  18. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    Shackle flip.
    Other than the problems associated with a higher CG I feel that my shackle flip is awesome. And towing the motorcycles really has not presented any problems.
    What are you planning on towing?
  19. Grim-Reaper
    7,385
    Atlanta
    Home brew flip.
    86 springs.
    2 extra leafs from original 75 pack
    1 inch Zero rate.
    6 inches of lift as measured against wifes stock 79 from top of axle to bottom of frame.
  20. Stephen
    Sep 15, 2000
    4,228
    144
    Carbondale Colorado
    You can probably figure out my vote. Same thing again, if the truck is set up for towing, the flip isn't going to matter. If it's set up for trail use only, it's probably going to tow like crap. If you're towing really serious trailers, you should probably look at not lifting the truck at all, and/or load leveling hitches, adjustable shocks, and a whole bunch of other stuff.
