Poll: RTV vs. Gasket for diff cover
Discussion in 'The Garage' started by Mastiff, Jan 27, 2006.
How do you seal the diff cover?
  1. Just RTV
    53 vote(s)
    61.6%
  2. Just Gasket
    10 vote(s)
    11.6%
  3. Gasket with RTV on cover side
    6 vote(s)
    7.0%
  4. Gasket with RTV on both sides
    16 vote(s)
    18.6%
  5. Who cares?
    1 vote(s)
    1.2%
  1. Mastiff
    Mastiff 1/2 ton status Premium Member
    Jul 21, 2002
    2,755
    48
    Tucson, AZ
    Kinda lame I know, but I'm curious what other people do when they pull/replace the diff cover.
  2. Chaddy
    Chaddy 1/2 ton status GMOTM Winner
    May 23, 2005
    4,110
    Salt Lake City,Utah
    I use Permatex Black RTV.
  3. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    I just put mine on with permatex Ultra Blue RTV. Has not leaked in the 4 days it has been on and filled with oil.:D
    Ira
  4. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    I got it down to a science now after many redo's :D
    Cover trimmed on the bottom so nothing hangs below diff , no peelbacks . Just the RTV marked for everything on the package front , the high heat orange stuff , set it up on the diff cover in a nice bead , push her on , tigthen her up , drink some beer and smoke for a loooooooong time , come back and fill her up . No leaks anymore :D:D:D:D
  5. loafer
    loafer 1/2 ton status
    Aug 19, 2003
    634
    Lyman, Maine
    I've found using a gasket with Never-Seeze on both sides works well. This allows for multiple disasemblies using the same gasket. It's also much faster for asembly/disasembly time; No need to scrape and clean the gasket surface. I've never had one leak using this method
  6. hack500
    hack500 1/2 ton status
    Sep 16, 2005
    523
    Templeton, Ma
    gasket with permatex High-tack on both sides.
  7. Fubeca
    Fubeca 1/2 ton status
    Dec 18, 2002
    2,100
    Denver Area
    Gasket for me!
    I use only a gasket, no leaks on 5 trucks. I just spent 20 minutes cleaning old RTV off of the axle housing and cover on my new-to-me truck. I prefer the ease of the gasket. I also don't hit my diffs on rock very often :) .
  8. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    I do the same.:D
  9. SkulzNBonz
    SkulzNBonz 1/2 ton status
    Feb 20, 2002
    4,522
    OKC, Oklahoma
    Red Permatex. Run a bead around the cover and circle each bolt hole. Let it set up about 15 minutes. Put the cover on, wait another 10 minutes, then fill er up. Done it that way more times than I can count.
    John
  10. theperfectgarage
    theperfectgarage 1/2 ton status
    Oct 5, 2005
    988
    tucson arizona
  11. BranndonC
    BranndonC 3/4 ton status
    Mar 18, 2002
    8,591
    Anaheim, Ca
    Permatex The Right Stuff has NO setup time, so you can put on the rtv, install the diff cover, and fill it right away, good idea to take some of this stuff on the trails with ya
  12. blackblazer717
    blackblazer717 1/2 ton status
    Jul 1, 2004
    470
    massachusetts
    i use the orange high temp stuff, but i liked the idea about the gasket with anti-seize on both sides. im gunna halfto try that some times, sounds interesting!!!
    LUKE
  13. Jonny-K5
    Jonny-K5 1/2 ton status
    May 27, 2003
    1,654
    SoCal
    i use the same stuff, on just about everything. expensive, but great product.
  14. Tux
    Tux Registered Member
    Jan 9, 2006
    14
    Phx
    Black rtv, I have done it this way since I used to work for uhaul. Never had a leak on diffs I did
  15. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,471
    5
    Olympia/Lacey, Washington
    I use a combination of the gasket with BLACK high temp RTV. no problems as of yet.
    I do the thin coating of black RTV on the cover, then,then the gasket, then place it on the diff housing and tighten 'em up. Same thing with the trans pan, with great success.
    I quit using that orange stuff long ago, i personally think it looks ghetto when it squeezes out and then there's orange crap smeared everywhere.:p:
  16. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    RTV... I prefer black but often all I have around is ultra copper.
    RTV contaminates the gear oil but I don't care. It's not usually in there long enough to matter.
  17. AKbigsub
    AKbigsub 1/2 ton status Premium Member
    Sep 9, 2005
    1,548
    16
    Anchorage, AK
    I use The Right Stuff also. And both diffs have a recessed drain plug un the bottom so I don't have to pull the cover as often (just a couple times a year to inspect the gears).
  18. colbystephens
    colbystephens 1 ton status GMOTM Winner
    Feb 24, 2005
    10,924
    20
    Oregon
    your poll doesn't have a naked option. that's against the rules! :deal: you could have at least said something like "rtv is great for sealing my nekkid a$$ crack"! SOMETHING. i think this thread should be deleted. just kidding.
    anyway, i use the black or orange RTV - it all works for me. never had a problem.
  19. 86k30
    86k30 Newbie
    Jan 29, 2004
    3
    i love ultra gray . my cover comes off so often that gaskets are hard to keep handy. always smashing the cover!!!!
  20. rcamacho
    rcamacho 1/2 ton status
    Jul 1, 2004
    1,324
    WA
    I've used RTV for the last two diff's. Works fine for me.
