POLL: Slip yoke vs Fixed
Discussion in 'The Garage' started by big pappa b, Jul 21, 2004.
  1. big pappa b
    big pappa b 3/4 ton status
    Jan 3, 2003
    6,328
    Falcon, Colorado
    Ok, here's the deal. I currently have Echobit rear flip w/57's and 4" TC's up front. T-Case is a slip yoke 205. I won a driveshaft over on PBB ($300 gift cert) and am trying to figure out what if I really need to upgrade to CV and fixed yoke.. so I'm looking for some opinions from those running 4-6" of lift.
    So here goes:
  2. 4X4HIGH
    Dec 14, 2001
    22,063
    71
    Pleasanton, CA.
    There is no substitute for fixed yoke and you can't go wrong with a CV shaft. /forums/images/graemlins/thumb.gif
  3. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Max out your rear travel on the driveshaft and see if it slips to far. If it doesn't then you don't need the fixed yoke. If it stuffs in to far under compression or pulls to far out under droop then get fixed yoke. It all depends on the amount of flex you have. 57's might be to much for a slipyoke.
    With my 52" rear springs I have not maxed out the slipyoke that I am aware of yet. But I don't have a huge amount of flex. More then stock but not like 57's.
    Harley
  4. 4X4HIGH
    Dec 14, 2001
    22,063
    71
    Pleasanton, CA.
    With a fixed yoke if you happen to break a U-joint you can just pull the shaft and drive home on the front. This can be done with a slip yoke also but not very easily and sure to make a mess even using the coke bottle trick.
  5. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    If you are scared of getting a little hot ATF on you when you are out offroading then offroading might not be the best sport for you. (not aiming it personally at you, in general) /forums/images/graemlins/whistling.gif
    Harley
  6. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    Harley
    I don't think that's the point. It's about how you wouldn't lose any ATF if/when you waste a driveshaft or a ujoint. Cleaning up spilled ATF on the trail is a huge pain in the ass!
  7. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    I get your point.
    I just like to be able to get spare driveshafts for $50 all day and not have to pay for an expensive CV shaft and then pay for another one for a spare. If i don't need the expensive shafts I am not going to pay for them. If i start to slip my yoke out to far then I will. But until then the slip yoke stays for me.
    Harley
  8. big pappa b
    Jan 3, 2003
    6,328
    Falcon, Colorado
    Dont't think I'll have to worry about replace one of these shafts..they are .250 wall
    So I think I'm convinced. Not I just have to tell the wife I have to spend more money after I just told her I'm done making any big purchases /forums/images/graemlins/1zhelp.gif
  9. spearchucker
    spearchucker 1/2 ton status
    Nov 17, 2003
    1,556
    Bay area, CA
    Choose your words wisely. It's not a purchase, it's an investment. /forums/images/graemlins/thumb.gif
  10. big pappa b
    Jan 3, 2003
    6,328
    Falcon, Colorado
    Oh yeah /forums/images/graemlins/deal.gif /forums/images/graemlins/woot.gif
  11. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    Get and upgraded slip yoke shaft and throw the existing one in the back as a spare. If you waste a shaft or joint just slap the spare one in and keep trucking........
