Poll: Steering Box Brace
Discussion in 'The Garage' started by stockk5, Mar 17, 2005.
Steering Box brace
  1. Yes, i do run one.
    188 vote(s)
    65.5%
  2. No i don't have one.
    99 vote(s)
    34.5%
  1. stockk5
    Apr 13, 2004
    2,037
    73
    Cromwell, CT
    Hey, i want to know how many of you run the bolt on frame brace for your steering box. This is one of my biggest fears for my truck is to have the frame crack and break and go through the hassle of fixing it and not being able to drive it for a while. So who runs it and who doesnt? Is the bolt on option a pretty set guarantee it will not break there? What actions usually help break it? deep ruts that turn? violent turns in bumpy terrain? I am saving up money now for one, so hopefully soon ill have it.
  2. smokkey1
    smokkey1 1/2 ton status
    Jan 7, 2004
    2,677
    Los Angeles, CA
    yes, I run one. It was one of the first things I bought for my sub.
  3. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    Not sure what happened to the other post but yea I weled up my cracks and made my own bolt on brace. with the cracks welded and the brace you are unlikely to have cracka again.
  4. tRustyK5
    Jul 23, 2000
    36,178
    1,387
    E-town baby!
    I run the weld in kit and the bolt on brace...
    Rene
  5. stallion85
    stallion85 1/2 ton status
    Jul 11, 2003
    3,659
    Cedar City, UT
    I run the bolt on, one of the first mods I did. I feel more confident with it up front, strength wise. If you plan to run big tires (37 and up) both the weld on and the bolt on would be the ideal setup.
  6. sapper
    sapper 1/2 ton status GMOTM Winner
    Jul 11, 2001
    3,052
    NoVa
    A few years ago i was out wheeling with The General, a old member that has got out of the sport for awhile but his truck was awesome, had the full gambit of crap , 1 ton, doubler, x-over, good engine, just a real well built truck, anyway he was doing a full throttle assault of a mudhole with 39.5/18 boggers with the bolt in brace and still managed to rip the steering box off, i guess the lesson was anything can break if you hit it hard enough, he then went to the weld in kit and hydro assist to solve the problem. The brace does work real good, I'v had mine for years running 40" tires but i drive alot different
  7. RootBreaker
    Nov 29, 2001
    5,117
    173
    Williamstown, NJ USA
    detroit and xover = needed.... so they say
  8. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    My frame was cracked , don't know if it was pre-brace or post-brace . I found it after cleaning my leaky steering off to look for the leak .
    I have no idea how long it was cracked before I saw it , but I drove on it cracked for 2 weeks prior to welding and the steering felt fine and the crack NEVER grew .
    Thats enough for me to believe the steering brace works .
    I imagine the crack getting worse and spreading to catastrophe if the brace wasn't there :D
  9. TWISTEDJACK
    TWISTEDJACK 1/2 ton status GMOTM Winner
    Jul 24, 2002
    882
    Boise, ID
    There are not guarantees in this business but it will definately help the frame problems. If you run crossover I would say it is a must due to the way it forces the frame worse than stock.
  10. rcamacho
    rcamacho 1/2 ton status
    Jul 1, 2004
    1,324
    WA
    Cracked - welding and bracing
    My frame has (1) 2" crack. I'm adding the weld in patch and the brace from ORD within the next two weeks.:(
  11. 1-ton
    Apr 17, 2004
    2,884
    165
    Las Vegas, Nevada
    A steering box brace is one of the first things I install on any of my trucks too.
  12. MTMike
    MTMike 1/2 ton status
    Feb 10, 2005
    2,992
    Billings, Montana
    The previous owner of my truck welded in a brace when he did all the work on it.
  13. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    They are a good safty item too add. Next K5 I buy will get both the bolt on and weld on braces no matter if the frame is cracked or not.
  14. sweetk30
    Nov 1, 2004
    25,546
    542
    horseheads , ny 14845
    the box brace tightened up my steering going down the road and that was with 38" tires great product.
  15. BigCountryx
    BigCountryx 1/2 ton status
    Feb 19, 2005
    519
    Gonzales, LA
    I'm installing one as we speak. The very first mod to my Blazer. Seems like one of the most important things you can do to these trucks, especially if you are planning on lifting and wheeling the thing!
    BTW - I've got a question about it. http://coloradok5.com/forums/showthread.php?t=132675
  16. jarheadk5
    jarheadk5 1/2 ton status
    Mar 6, 2000
    4,389
    PA
    It was the first mod I did, on the advice of the gurus here at CK5. Steering was noticeably better after installation...
  17. mtn. burb
    mtn. burb 1/2 ton status
    May 13, 2004
    1,260
    Ojai Calif.
    I put one in, and the weld in patch.
    Then a week later installed a ram assist, which relieves the box of much stress.
    You might not need it with a ram assist, but it is good insurance.
  18. GM Man
    GM Man 1/2 ton status
    Jan 12, 2003
    549
    Denver CO
    Very first thing I installed on my Jimmy.
  19. MTMike
    Feb 10, 2005
    2,992
    Billings, Montana
    It's cheap insurance - I really don't feel like havnig to pull my rig out of the mountians with the steering box and the front part of the frame dangling from the hoses.
    I was given a "Don't ask me how I know" story on that one and it's what sold me on it.
  20. rcurrier44
    rcurrier44 1/2 ton status
    Oct 13, 2003
    320
    I have parted out 5 70's chevy's over the past 3 years and all but one had cracks around the steering box area. They were all stock half ton 4wd trucks...
