Poll: What broke in your 10/ 12 bolt rear?
Discussion in 'The Garage' started by 84k5, Jun 17, 2003.
  1. 84k5
    84k5 1/2 ton status
    May 13, 2000
    2,949
    Dublin, CA
    Thanks for entertaining me. /forums/images/graemlins/grin.gif
  2. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    Entertaining's my business and business is good! or was that killing?? /forums/images/graemlins/thinking.gif
  3. yellowK20
    yellowK20 Well Lubricated Premium Member GMOTM Winner
    Dec 26, 2002
    7,603
    555
    Wasilla AK,
    One shaft in three years which is pretty good Cuz I have about 425HP 4.88 gears powertrax locker and 37" Mtr's and a TCI prepped 700r-4 /forums/images/graemlins/truck.gif
  4. Rolled
    Rolled 1/2 ton status
    Jun 16, 2002
    683
    Anchorage, Alaska
    axle bent durring roll over.
  5. 83ZZ502_Jimmy
    83ZZ502_Jimmy 1/2 ton status
    Feb 7, 2001
    3,103
    Richmond, VA
    Lets see-
    I've broken:
    Side Gears
    Spider gears
    2 gov loc's
    3 ring gears
    2 pinion gears
    1 axleshaft
    1 open carrier
    1 older posi unit for 10 bolt
    1 crosshaft
    I think thats it for now...
    John
  6. WakeBoard&4X4er
    WakeBoard&4X4er 1/2 ton status
    Jun 29, 2000
    2,325
    Lee's Summit, Mo
    Ring and Pinion
    Because of
    Stock Carrier
    Because of
    bearing on the Carrier when out!
  7. 76k5Blazer
    76k5Blazer 1/2 ton status
    Sep 25, 2002
    176
    tracy ca
    you need to add nothing i was smart and threw the 10 bolt or 12 bolt away and droped in a 14 bolt ff /forums/images/graemlins/rotfl.gif
  8. woody9
    woody9 1/2 ton status
    May 27, 2001
    602
    Howell, MI
    no follow-up survey on why it happened the 2nd time? /forums/images/graemlins/thinking.gif
  9. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    20,716
    Undisclosed Location
    Pinion bearing, which in turn lead to ring and pinion......
  10. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    12 bolt: Ripped the teeth off of the ring gear 3 times in 3 years. /forums/images/graemlins/eek.gif
    10 bolt: Pounded the hard facing off of the spider gears, which then chewed up the bearings. /forums/images/graemlins/frown.gif
    Mini-10 bolt (S-10): Broke teeth off the pinion gear, with a weenie TBI 4.3L V6 and 30x9.50's! /forums/images/graemlins/shocked.gif
    I'm a big fan of 14-bolt FF's these days. /forums/images/graemlins/thumb.gif
  11. 79Beast
    79Beast 1/2 ton status
    Dec 9, 2001
    1,155
    Georgia
    Where's the vote for "more than one of the above at the same time"?
  12. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    My buddy blew the spiders out of the 12-bolt in my '66 C10. One spider split in two and as it fell clear of the case, the ring gear picked it up and pressed it out through the diff cover. I looked really neat /forums/images/graemlins/thumb.gif
    I welded the cover and back on it went /forums/images/graemlins/grin.gif
  13. 87GMC
    87GMC 1/2 ton status
    Nov 5, 2001
    653
    Olathe, KS 66061
    Pinion bearing
  14. Blazinaire
    Blazinaire 1/2 ton status
    Mar 17, 2002
    1,262
    Santa Maria, CA
    lets see... blew the 10 bolt govlok, snapped a 12 bolt housing clean in half (that's quality carnage folks!), blew 12 bolt ring/pinion (my own fault, thats what I get for setting up my own gears) broke a 12 bolt side gear...
    All in all I'm pretty happy with my 12 bolt /forums/images/graemlins/cool.gif
  15. 89GMCSuburban
    89GMCSuburban 1/2 ton status
    Nov 15, 2001
    3,005
    Thornton, CO
    Someone replaced the pinoin seal without replacing pinion nut. Backed off on me while driving...dropped pinion into ring gear and carrier. Broke teeth on pinion and ring gear and ground chunks off the gov-loc.
  16. MEPR
    MEPR 1/2 ton status
    Oct 21, 2002
    1,546
    McChord AFB
    well my 10 bolt has yet to break (its under alot of stress too, 2600lbs of truck on it, 27.5s and a whole whoping 1.8L isuzu pumping out 125hp and 150ft-lbs).
    But i know a guy who busted a 10bolt front case clean in half on his /forums/images/graemlins/burb.gif /forums/images/graemlins/rotfl.gif
  17. Sinful_Nature
    Sinful_Nature Registered Member
    Jun 14, 2002
    90
    Raymond, NH
    Non of the above for me. I had a seal go, and as I was in the process of changing it realized that the pinon screw had snapped, I thought about trying to remove it, however having a parts truck with 3/4 ton running gear under it, decide it was to make the swap.
  18. Emmettology 101
    May 9, 2000
    8,126
    FL
    Only thing I have broke on my 12 is the spiders. Blew them into tiny chunks and out the rear cover... got a spare set I had and welded them up. No problems after that! The following weekend I had the truck bouncing off the ground doing a hill with waterfalls(and heavy on the juice) and nothing broke... Thats when I stood it up on the spare tire!
  19. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    I chose ring gear, even though it is impossible to tell if it was the ring or pinion that let go first. When they fragged it bent the mounting surface of my factory limited slip. JUNK! /forums/images/graemlins/angryfire.gif
  20. muddysub
    Jun 23, 2001
    10,452
    489
    my garage, Henderson, NV
    40" TSLs and a stage 2 shift kit did it for mudbogAD, jus forgot to let off the gas for the 1-2 shift and bang!
