POLL ......who makes the BEST distributor caps and coils??
Discussion in 'The Garage' started by hi pinion, Oct 21, 2004.
  1. hi pinion
    hi pinion 3/4 ton status
    Sep 25, 2003
    5,354
    **PLUMBING THE WORLD**
  2. diesel4me
    Jul 24, 2003
    17,534
    920
    Massachussetts
    I've never used any of those "hot rod" ones listed--they are probably better quality than most "regular"replacement ones.At the parts stores I worket at,we usually had 2 brands of ignition parts,most popular were Standard Ignition(the "Blue Srteak"ones have brass terminals and higher dilectric strength plastic)and Filko,both were prefered by the shops and mechanics by far,unless they wanted a "cheapie",then I'd sell them an "E-Tron" brand cap--actually the E-tron wasnt bad--they made a cap just like the Blue Streak ones with brass terminals,it was even blue for about 10 bucks for an HEI one,whereas the Blue Streak on sold for over 20 bucks.I've had very little troble with distributor caps since they started using that different type of plastic on the HEI ones--they dont crack or carbon track anywhere near as often as they did on point style distributors--the rotors still get carbon tracked or "punched through"(when the spark burns a hole through the rotor,and gronds out on the distributor shaft)quite often--I see it mostly on the 4.3's and newer GM's with the small round style rotor more than the V8 style rotors for some reason. /forums/images/graemlins/crazy.gif
  3. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Standard Ignition, BLUE STREAK
    Absolutely the best cap & rotor on the market, no question.
    Look for an X at the end of the part number. /forums/images/graemlins/thumb.gif
  4. BranndonC
    BranndonC 3/4 ton status
    Mar 18, 2002
    8,591
    Anaheim, Ca
    why would you make the poll so i cant view the results if i dont have any valuable input, yet still wonder the same question you do, now i can get any results till halloween /forums/images/graemlins/dunno.gif not mad, just wonderin why people do that /forums/images/graemlins/thinking.gif /forums/images/graemlins/whistling.gif
  5. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    It defaults that way
  6. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    For a stock ignitions system, whatever the parts store sells. I do like MSD for preformance ignitions.
  7. JK5
    Jan 31, 2002
    3,453
    Norton, Oh
    Yep...I aggree with that...that's what I run.
    They really sell quality ignition parts..
    Not like the Autozone...chinese crap. /forums/images/graemlins/wink.gif
  8. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    Yep, I'm on this same page too. One thing I'll add though.
    Specify marine application!
  9. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Autozone is Wells.....
    Actually not crap, just not professional quality like Standard Ignition. Their, "Conrad" is really Wells' premium line...not bad....but certainly not Blue Streak either. /forums/images/graemlins/thumb.gif
  10. hi pinion
    Sep 25, 2003
    5,354
    [/ QUOTE ] Because Halloween is my birthday , and this is my present to myself /forums/images/graemlins/rotfl.gif /forums/images/graemlins/histerical.gif
  11. hi pinion
    Sep 25, 2003
    5,354
    BTW i was looking for hotter HIGH spark combos,not stock, stock sucks /forums/images/graemlins/histerical.gif /forums/images/graemlins/thumb.gif
  12. BranndonC
    Mar 18, 2002
    8,591
    Anaheim, Ca
    not this way "Votes accepted from (10/21/04 07:32 AM) to (10/31/04 07:32 AM)
    You cannot view poll results until the poll is over."
  13. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    A distributor cap doesn't make spark, and is incapable of making spark, "hotter." Standard's blue streak is far superior to any aftermarket cap I've ever seen, and I'm pretty sure I've seen nearly all of htem.
    In fact, even the less expensive Standard ignition cap is nicer than any aftermarket cap.
  14. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Oops, nevermind. /forums/images/graemlins/confused.gif
  15. 86chevybanshee
    86chevybanshee 1/2 ton status
    May 15, 2004
    917
    beverly MA
    where can i purches one of these "blue streak" caps?
  16. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    I'd vote for blue streak too, we stocked it. great stuff.
  17. hi pinion
    Sep 25, 2003
    5,354
    [/ QUOTE ] No, but i think the coil does......
  18. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    At a professional parts store (IE, not Autozone, Advance, etc., a REAL parts store)
    Look for this logo:
    The blue streak stuff will be medium blue and the part number end in X. The regular standard ignition stuff will be a black cap. Both are very good quality, the blue streak is best though, REALLY thick plastic caps.
  19. JK5
    Jan 31, 2002
    3,453
    Norton, Oh
    I used a wells coil...(China STAMPED on it)
    on one of the Tow motor's from work..
    It lasted a year. /forums/images/graemlins/crazy.gif
    I've using Standard for years..
    I've gotten 8 years from one of the Dist. Caps...
    I STAY away from autozone...when it comes to ignition..
    Especially wires!!! /forums/images/graemlins/yikes.gif /forums/images/graemlins/yikes.gif
  20. hi pinion
    Sep 25, 2003
    5,354
    Hey...blue streak isnt on the LIST /forums/images/graemlins/histerical.gif So your telling me a mallory isnt as good as a blue streak??? /forums/images/graemlins/thumb.gif
