Poly Body Mount Question
Discussion in 'The Garage' started by merc359, Nov 14, 2006.
  1. merc359
    merc359 1/2 ton status
    Mar 25, 2005
    103
    Vancouver, BC. Canada
    Hello,
    I have a 1979 Chevy Shortbox 4x4 and I am replacing the body mounts on the entire truck. When I tore off the old tub, I tossed everything out with it as every washer, sleeve, and mount was destroyed and nasty.
    Now I am starting at an LMC Truck catalog and they offer a complete mounting kit WITH HARDWARE. After pulling myself off the floor (I realized it has everything I need) I was hit with the reality that it is all rubber. Now, I know the rubber is going to last at least a few years. I am not really worried about that, but here is the question:
    Is there a kit out there that is ALL poly? If I can do the entire thing with poly now, why not do it?
    Otherwise, I am going to end up with poly cab mounts, and rubber everything else - is there any known issues with this?
    Hope someone has some insight...
    Rowan
    Merc359
  2. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    I used ORD's poly mount kit.
  3. merc359
    Mar 25, 2005
    103
    I was just looking at their stuff, and it looks great except it doesn't include the hardware. I am beginning to suspect I might have to purchase a complete kit from LMC just to get the hardware, and then buy the poly kit so I have the poly.
    Sounds goofy, but I cannot see another supplier. Good lord, if LMC had an "all poly" kit they wouldn't be able to keep them in stock. I know 3 guys around here having the same issue as me.
    Rowan
    Merc359
  4. merc359
    Mar 25, 2005
    103
    You know, I am staring at my truc now, and I think I see why no kit seems to quite work. I have a 2WD cab that I converted to a 4x4 cab. I see the listings and pictures of the mounts appears slightly different.
    If anyone has a digital camera, and 2 minutes of their time, I would love to see someone take a photo of the rear cab mount from their 73-80 4x4 PICKUP so I can see if I am working with the right stuff.
    Pretty please...
  5. shane74
    shane74 1/2 ton status
    Feb 12, 2002
    4,100
    Vancouver, WA
    Most shops don't carry it, but yes there is a poly kit that has everything but the bolts. Energy Suspension makes it. I am putting one of the kits my rig this week. PM me for a price if you are interested.
  6. diesel4me
    Jul 24, 2003
    17,568
    943
    Massachussetts
    No pictures,but...
    I have removed dozens of Chevy cabs--your right,the rear rubbers under the back of the cab on early 73 up trucks are much taller on a 4x4, than 2wd ones are..at least twice as thick,about 4" tall VS 2" or less for the 2wd versions..not sure,but I believe 4x4 and 2wd crossmembers the cab mounts sit on are different too..:crazy:
  7. 1977k5
    1977k5 3/4 ton status Vendor
    May 26, 2003
    9,995
    133
    I replaced all my body mounts with poly ones and it came with a couple extras, probably for this exact reason
  8. sweetk30
    Nov 1, 2004
    25,548
    543
    horseheads , ny 14845
    if you need to go get junk yard mount stuff from 81-up. then get a suburban body mount kit. and hog out the frame holes to take the 81-up mounts. then in the burban kit there is a #4 or #5 position mount thats 1" thick and needs to grind off the metal indexing tab to make it fit. this will fit inbetween the rear cab mount and tha cab for a 81-up 2x4 cab on a 80-older frame. i can get pic if you need me to.
  9. merc359
    Mar 25, 2005
    103
    Thanks for all that input! That is great.
    I have a complete mounting kit arriving shortly. And I am going to mock it all up to make sure it fits and then purchase the relevant / required poly components.
    The 2x4 cab is going on a 4x4 frame. I know it's gonna be fun...
  10. sweetk30
    Nov 1, 2004
    25,548
    543
    i just did a 2x4 87 cab on a 79k30 with 4 speed tranny. did a 2" body lift and have 2" of the tranny tower in the cab. close to stock hight. boot will cover just fine.
  11. Chevy305
    Chevy305 6 Lug 14bsf Status Premium Member GMOTM Winner
    Jan 23, 2006
    11,232
    490
    New Hampshire
    Did you use the correct tranny hump?
