poly body mount questions
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by kumma, May 10, 2001.
  1. kumma
    kumma 1/2 ton status
    Oct 29, 2000
    380
    Novi, Michigan
    Well i just got done wrestling with 5 body mount bolts and every one snaped off. The bottom mounts on all of them were gone! my body was just floating on the frame, i guess thats why it rattled so much. My question is with poly body mounts do i reuse the metal hardware from the truck or do i just scrap it. Im looking at energy suspension body mount kit. Also grade 8 or 5 bolts to mount everything?
    thanks
  2. fr8train
    fr8train 1/2 ton status
    Aug 2, 2000
    1,712
    Maryland
    The body kits that I have mounted all came with the hardware. Scrap the old junk. Grade 8 is what you want. I cant remember off hand wether or not the E.S. kits come with them or not.
    [​IMG] Dont steal my truck..I dont need anymore worthless junk over my fireplace.
  3. JST12
    JST12 1/2 ton status
    Aug 29, 2000
    192
    Garland, TX
    Kumma,
    I just got done with the energy body mount installation. The hardware is all grade 5. You do not need to save any metal pieces except for any square shims which were originally installed from factory between rubber mounts and the body itself. The kit comes with poly mounts, tubular inserts, big and small washers and nuts and bolts. Good luck. JT
  4. kumma
    Oct 29, 2000
    380
    Novi, Michigan
    Thats good info, one other thing where did you guys buy the mounts from?
    Craig
  5. taterblazer
    taterblazer 1/2 ton status
    Feb 2, 2001
    277
    Boise, ID
    Keep all your old parts until your done. Experience.
  6. JST12
    Aug 29, 2000
    192
    Garland, TX
    I get most of my car/truck parts from <A target="_blank" HREF=http://www.summitracing.com>http://www.summitracing.com</A>. They have free shipping and excellent prices. And, yup, don't throw away anything until the job is done. Never know when you'll need one of the old pieces. JT
  7. dyeager535
    26,976
  8. californiak5
    californiak5 1/2 ton status
    Oct 25, 2000
    820
    Oceanside, Ca. 92056
    Try Stephen at ORD........<A target="_blank" HREF=http://www.offroaddesign.com>http://www.offroaddesign.com</A>
    He has complete poly kits and knows all about the K5 world.
    See Ya,
    Keith
    [​IMG] <font color=green>Born to Drive My K5</font color=green> [​IMG]
  9. Boss
    Boss 1/2 ton status Author
    2,550
    Maryland
    No, no, Keep the "factory sleeves" that went through each rubber. unless they're rotted to the core. You may have to get new ones. I'm sure you can get away with not have them, but they are necessary. They keep the bolts from moving around in between the bushings. They're like a sleeve with a huge washer on top that sits on the bushing. and NO, your E. S. kit did not come with these. They only came with like 2 sleeves (maybe 4) that goes inbetween the mounts at section 5 (the two last ones by the tailgate). Yes, I've done this conversion and that's how I know.
    Boss
    ps, it probably wouldn't kill yah to run without them though, but they are there for a reason.
    <A target="_blank" HREF=http://www.boss.coloradok5.com>http://www.boss.coloradok5.com</A>
  10. dyeager535
    26,976
    On the ER kit I just bought for my car, the "sleeves" were included. Appear to be cadmium plated, as well as the washers. Interestingly, the GM car kit did NOT come with bolts, but suspension restoration reps knew that and told me when I asked before purchase.
    Dorian
  11. bad_bo_ti
    bad_bo_ti 1/2 ton status
    1,027
    OhiO
    just got done with the energy body kit and a body lift. grade 5 yes and grade 2, the bolts are 5 but everything else is grade two i was tld this the guy i am going through for all my grade 8 hardware. you do use all the metal brackets too. might need to shim alittle i had to, so the body is fairly even.
  12. surg82k5
    surg82k5 1/2 ton status
    Feb 7, 2001
    416
    San Antonio,Texas
