Poly body mounts on a suburban? and poly engine mount ?
Discussion in 'The Garage' started by y5mgisi, Jun 27, 2005.
  1. y5mgisi
    y5mgisi 1 ton status
    Aug 11, 2002
    17,156
    247
    Portland Oregon
    Would poly bofy mounts be agood idea on a 90 suburban. At first thought i would thing that the frame would stil try and flex just as much and drap the body around more, thus doing damage to the body? am i crazy? Also on my 78 that i did the caddy 500 swap in i used ORD's 2" round poly bushings for the mounts. Shoud i also do the tranny mounts poly or is it ok to leave the rubber ones back there? Thanks!
    Mitch
  2. dremu
    Feb 27, 2000
    15,968
    461
    East of San Francisco
    I've still got rubber engine and tranny mounts, but I gather that mixing poly and rubber on the drivetrain will cause heartache, i.e. broken rubber mounts.
    Wow, that sounds like a bad porn movie.
    Anyway, general rule as I understand is don't mix; if you're gonna do poly engine mounts, do poly tranny and t-case if so equipped.
    -- A
  3. y5mgisi
    Aug 11, 2002
    17,156
    247
    Portland Oregon
    ok thats what i heard too so must be the case then. Does anyone know about te poly body mounts on the burb?
  4. opfor2
    opfor2 1/2 ton status
    Oct 28, 2002
    375
    Ventura County, CA
    I changed all of my mounts on my 90 Blazer and all went well. You do feel the "road" a little more but no big deal.
    Good Luck
